Winter Washing
#41
Wiping down a car after a drive through wash could possibly be the dumbest move ever, same with the guys using the wash brush at the car washes. I only ever drive through and let it air dry. Or on the rare occasion I'll do the drive through wash, head home, park in the garage and if it looks like the wash got most of the shit off I'll do a waterless wash in the garage with multiple buckets and a very careful hand. I also have all the gear for paint correction so it's not a big deal for me if I get some swirls when the summer rolls around.
#42
No, they don't apply a rust inhibitor from the factory, you're clearly mistaken if you think they do. The dealerships will always offer to sell you a rust inhibitor when you purchase new.
I don't think the discussion on washing cars is referring to ensuring the top of your painted hood is clear of salt, the washes are mostly to remove the salt build up around the fenderwells, bottom of the doors etc.
The people who don't wash their cars must have an awful amount of containments in their paint after a full winter season with no washing...they probably never claybar either so I bet their paint will look like shit in a couple years. I'd love to see the condition of the paint under a pile of bird shit that sat for 4 months haha.
You can remove all of that in a self serve car wash and high pressure washes are bad for the seals of your vehicle.
That's the point of clay bar, to remove contaminants from your paint. Either DIY it or hire a detailer. I'm not saying you should not wash your car. What I'm saying is if you care about your paint you can hose down your car instead of going to a cheap carwash. That's all. Cheap car washes make their business from being fast not careful.
For example in the winter if weather permits I wash and dry or I leave the car alone for whatever amount of time. When it gets better I wash, dry and quick wax. Under carriage gets hosed down now and again but I leave the paint alone if I can't do a good job. Also high pile drying towels are great at cutting down dry time. I just use those if water stay's water long enough and get a clean finish. Just need to be gentle and fast. Just depends on my mood. Come summer it get's clayed and worked on again. No corrections unless absolutely necessary. I have a finite amount of paint so I'm not going to keep cutting it down. Also I jack up the car and inspect the under carriage to see if there's any rust creeping in from.
d1sturb3d119 (11-13-2014)
#44
That is true, the undercarriage is galvanized. But similar to paint, rocks and dirt chips the galvanized item to bear metal. So after a year or even less, it is safe to say that your undercarriage is basically completely exposed raw metal which is why people still rustproof their cars.
#45
#46
True. Underbody coating does help. The 3g's are all done if you have a look under them. Also living around coastal areas gives you the same effect. Salt spray from the ocean is present in the air. Same issue. Really the only place you're safe is in the dessert with no snow or in an NSX. That's my next proposal for a safe winter proof car!
#48
I will break out the hose right after any sort of heavy salting or snow storm and blast any excess salt off the bottom of the car.
#50
Its not pure incarnate evil either but understand how touchless car washes work. They're really hard on your paint to try and remove dirt through the force of the water. But by doing that it can force water in places it shouldn't be. Cars are not specifically designed for that and over time, rubber does fail. Also the most minute rock chip can be blown open and you can have paint ripped off because it hit a damaged area on your paint. I'd suggest not using it often especially if you care about keeping the car in good shape for years and years to come. If you don't care about that then its not a problem. Nothing wrong in not caring about paint where you're really really particular.
