Will any brand engine air filter do ?
Just wondering. Outside of K&N(which I have decided against despite 6 extra HP ) they are all between 11-15 dollars. Am I good just popping anyone in there ?
Thinking of going with this one...
go for OEM.
however; if you want you can just go to autozone and pick up their brand of filter.
but honestly, this car is pretty much the same as your 3G.
anything you did to the 3G, you can do the same for your new 4G.
justnspace (02-20-2015)
I tried the K&N, no difference, I guess the only advantage is being able to clean it and re-use. FRAM is super cheap at my local farm & fleet, easy to swap out a new one every oil change, about once a year for me
Amazon.com: Purolator A36308 Classic Air Filter: Automotive
K&N can be good, however a lot of people tend to over oil them when reusing them and end up causing engine problems. IMO, the disposable ones are better.
I only have 12 thousand miles on mine too! Low mileage but my car is a 2012.
Had no problem running K&N during past four Honda/Acura vehicles. I clean and re-oil every 30K miles and good to go.
When it comes to any replacement parts, there always will be pro/con with each product, just like OEM oil filters made by Fram debate. Use whatever you feel comfortable and believe will get the best job done at good value.
Abe_Froman
09-16-2015 02:27 PM
