What is the best automatic transmission fluid for our 4G TL?????
Old 11-06-2019, 11:31 AM
  #41
mrphilipanderson's Avatar
Originally Posted by csmeance
smooth = more friction modifiers which means more slippage of clutches
Harsh = less friction modifiers which means less slippage of clutches
Hence the 3G TL folks using a mix of redline racing ATF (little Friction Modifiers) and D4 (lots of friction modifier). The more they slip, the more wear and tear!
is lsippage of clutches good? Isnt it desireable to have smooth transmission?
Old 11-06-2019, 11:49 AM
  #42
I am considering using LubeGard Platinum Additive. Ive been speaking with their Product technical Support team for a few weeks now with questions - they are so patient and informative. On the phone, via email, and in writing.
It main purpose if to protect transmission from and marginally recue normal wear and tear with its blend. 1oz. per quart suggested to fresh transmission fluid. I just got a new transmission and I want to keep it running. This would be my second.
Clearly acura transmissions arent as reliable as Id like them to be. So the first transmission i did ONLY OEM. no additives whatseoever....this time around Im gonna try additives.
Old 11-06-2019, 12:27 PM
  #43
Latent car nut
horseshoez's Avatar
Received 2,008 Likes on 1,410 Posts
Automatic transmissions, like much else in life, are a compromise. The designers of your transmission designed for a very specific ATF (DW-1) which allows for a specific amount of slip, any more slip and the clutches will wear out too quickly, any less slip and there will be extra shock transmitted to the drive train which can accelerate damage to transmission internals and external drive train components alike. If you feel like second guessing Honda's engineers by using an unapproved ATF brew, just keep in mind, they know a lot more about the design than the rest of us, so basically, you're on your own.
csmeance (11-06-2019)
Old 11-06-2019, 12:48 PM
  #44
Well when you put it that way LOL....
Old 11-10-2019, 06:01 PM
  #45
jjrphs's Avatar
In comparison to the dw1 are the. Shifts smoother in your TL OR more firm? I am asking because I am a fan of smooth. I dont like to feel the shifts. I like a seamless climbing of the revs.
Honestly...I can't tell a difference. I've seen other comment that MaxLife ATF shifts slightly firmer in their Honda / Acura. Hope that helps.
jbankheadgray
06-19-2015 09:13 PM
Anicra
05-08-2015 10:26 AM
SilverJ
4G TL Problems & Fixes
03-06-2015 08:20 AM
edison9114
11-17-2012 04:42 PM
mafiosi
12-08-2011 07:00 PM
Quick Reply: What is the best automatic transmission fluid for our 4G TL?????
