Want to DIY fog lights but not sure how..
welcome to Acurazine..... your new favorite website.
and congrats on the drug.... i mean the car.
It very easy to change the bulbs. Just remove the front tire liner. You do not need to remove it all , just at the bottom. then you will have access to the fogs. Remove the power connectors before removing the bulb.
jwu (06-17-2012)
jwu (06-17-2012)
Technically you don't have to. If you know what wire to splice and a place to mount from the wheel well then you don't need to take the bumper off. I did that once but I remounted the ballasts somewhere else when I took the bumper off
just did it today, took about 15 mins per light.
step 1, turn the wheel away from the light you want to do.
step 2, unscrew everything holding the bumper in.
step 3, just pull away the bumper a little bit so your not forcing any seams or creases to form.
step 4, hook up your ballasts and lights. i installed the lights bulb first and then the ballast. tested everything out. then mounted it with the twisties and double sided tape.
step 5, screw everything back in.
honestly its not that hard, just dont force anything, and you'll be alright. make sure your well lit in the wheel wells. it wouldve helped greatly if i had a lift, but it wasnt necessary.
good luck.
good luck.
InFaMouSLink
10-27-2015 07:51 PM
sockr1
10-01-2015 02:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 03:03 AM
