TWM 'Type R' weighted shift knob installed [pics]
8 Attachment(s)
So I bought a graphite/engraved 'Type R' style weighted shift knob from TWM Performance a few weeks ago, and thought I'd post a couple pics.
Finished product: Attachment 100624 I weighed the new shift knob against the OEM 6-spd knob, and found the OEM weighs 140 grams, while the weighted TWM knob weighs 400 grams. Attachment 100625 Attachment 100626 The only real problem with installing aftermarket shift knobs on the TL is finding a way to keep the shift boot from flopping around, since there are clips underneath the OEM knob to keep it on. Luckily I happen to run a 3D printing lab at work (I'm a mechanical engineer), so I was able to design and 3D print a small insert to sit inside of the top ring of the shift boot to keep it centered on the threads, keeping it from flopping laterally. It keeps itself up due to a bend in the threaded rod just underneath the silver ring, so it also doesn't fall down due to not being clipped to the knob. Attachment 100627 Attachment 100628 3D printed insert Attachment 100629 Room for extra floppage without the OEM knob Attachment 100630 Part inserted, floppage removed. Attachment 100631 Installed close-up So far, I love the feel of the shifting, definitely feels easier to shift into 2nd and 3rd. I also like the sort-of matte graphite finish, since it blends in with the other greys and blacks of the interior and center console really well. I'm just waiting until the middle of August when I accidentally burn a 6-spd shift pattern in the middle of my right hand... |
awesome!!
i agree with you, the graphite color looks AWESOME!!!!!! |
That insert gets an A++++ from me. Good job on that. It's nice to see a well thought out solution. Congrats!
Looks great. And I still really like the looks of our 4G interiors (especially with 6MT).
(But of course, those extra grams of weight will cost you dearly in 0-60 launches). |
Originally Posted by JM2010 SH-AWD
(Post 15998233)
Wow that look beautiful dude, much better than the chrome finish on the stock. Awesome choice.
Nice! Do you have an stl file for those of us with printers that might want to change knobs in the future?
Originally Posted by zmt
(Post 15998860)
Awesome work man. What material did you print it in? I'd imagine PLA is good enough unless you live in hotter climates like Florida. PETG is a pretty awesome material, its higher melting temperature should help withstand the summer heat a lot better.
Originally Posted by jefflikesbagels
(Post 15999120)
And I've done tests with printed prototypes using the same materials at 265 F with no problems, so it'll hold up pretty well. Besides, if the inside of my car hits 265 F, I've got bigger problems lmao. |
That first photo is sharp. Saw the Mettler Toledo and figured you would be up to some engineering. AQE here in north NJ with a '10 SH-AWD M/T as well.
1 Attachment(s)
I attached a .zip file with the .stl and an IGES file if anyone needs to regenerate the .stl for themselves.
Originally Posted by Rancher2005
(Post 15999333)
I got one of these knobs last year and had a similar problem, was looking into engineering something along the lines of what you did, but found an acceptable solution from TWM.
They make a retainer insert that threads into the bottom of the knob and holds the boot up. It replaces the factory one. It involves taking apart the center console area to access the bottom of the boot Here is the part: https://www.twmperformance.com/boot-retainers/boot-retainer I can post a picture of the finished result tomorrow when I get home. |
Originally Posted by alxhastngs
(Post 16004255)
They make a retainer insert that threads into the bottom of the knob and holds the boot up. It replaces the factory one. It involves taking apart the center console area to access the bottom of the boot Here is the part: https://www.twmperformance.com/boot-.../boot-retainer I can post a picture of the finished result tomorrow when I get home. |
https://cimg3.ibsrv.net/gimg/acurazi...cdc185eab8.jpg
Here's mines but with a Civic Type R knob. |
As promised, here is mine with the TWM adapter:
https://cimg8.ibsrv.net/gimg/acurazi...a5a7adac9a.jpg https://cimg5.ibsrv.net/gimg/acurazi...7e564f72f7.jpg |
