Transfer case fluid recommendation....
all,
I just did my 3rd drain and fill ATF today to complete 3x3 method in 2 months time span and I've noticed the transfer case fluid was left untouched. I'm thinking about changing it this coming weekend but need some opinion on what fluid i should use. The options listed below:
The Amsoils need to be ordered and will take a couple days for shipping. I used the Mobil 1 75W-90 before for my G35 coupe and happy with the result but Amsoil received high feed back from fellows in here. Besides, is it a full quart required for drain and fill? Thanks.. |
If you go Amsoil, they recommend the Severe Gear
AMSOIL Online Product Application Guide Personally, while I like Amsoil, I went with Royal Purple which was also easily bought at most stores. |
I used Redline synthetic 75w85 for my last change (which is the specified weight).
It's the only synthetic I could find in this weight. |
Thanks for the replies guys.
Did you guys feel any differences with either Royal Purple or Amsoils compare to OEM?? |
Originally Posted by Cooldude01
(Post 15488328)
Did you guys feel any differences with either Royal Purple or Amsoils compare to OEM?? I didn't notice much of a difference between the two fluids, but I only had ~25k miles on the car when I did it. |
The OEM fluid for the transfer assembly is Acura or Honda HGO-1 Hypoid Gear Oil GL-5 75W-85.
Acura P/N: 08200-9014A Honda P/N: 08200-9014 |
Originally Posted by TheMuffinMan
(Post 15488330)
So one issue is there really isn't an OEM replacement 75w90 fluid to use! Asked my dealership and used my internet skills - doesn't exist.
I didn't notice much of a difference between the two fluids, but I only had ~25k miles on the car when I did it. From my understanding, transfer case is supposed to transfers power from the transmission to the axles by means of the drive shaft. Replace the OEM fluid with Amsoils synthetic will help smoother the process, hence the car will feel less sluggish when accelerating...Unless there isn't any significant different between OEM fluid and Amsoils then the sluggish condition still exist regardless of what fluid I use... please correct me if I'm wrong... |
Originally Posted by EE4Life
(Post 15488338)
(Post 15488338)
Acura P/N: 08200-9014A Honda P/N: 08200-9014 I asked my dealer and they didn't stock anything, I also looked at Bernardi which doesn't list that fluid either. Acura Fluids - Bernardi Parts |
If you notice a difference in driving after any kind of fluid change, other than perhaps the auto trans, you either had a problem brewing or you're having a problem brewing. You might get a very slight change in fuel mileage but it would be so small it could only be measured in a controlled type laboratory environment.
Just make sure you get the correct kind. Some gear oil is corrosive to yellow metals from what I read.
I personally used Mobil 1 for the T-Case, Acura dual pump for the Diff, and Acura MT fluid (6MT) for the trans. Waited 1 week, then did it again with an oil change. I also had 55k miles on it when I did this. |
Originally Posted by Reorge
(Post 15488688)
Originally Posted by hurleyman123
(Post 15488858)
(Post 15488371)
Nice!
I asked my dealer and they didn't stock anything, I also looked at Bernardi which doesn't list that fluid either. Acura Fluids - Bernardi Parts This Bernardi Honda link under Chemicals/Fluids -> Fluids shows it. 08200-9014 | Honda HGO-1 Hypoid Gear Oil - Bernardi Parts Usually the Honda branded fluid is cheaper, but in this case the Acura branded fluid is cheaper. $13.76 (Acura) vs. $14.91 (Honda). Acura Genuine Oils and Fluids Applications Honda Genuine Oils and Fluids Applications https://acurazine.com/forums/problem.../#post15191527 |
Or for acurapartsforless.com
HGO-1 GL-5 75W-85 | Genuine Acura | 08200-9014A In general for this fluid, you have to search for the part number on these sites. |
