Top End Speed?
Top End Speed?
I thought I read somewhere that the top speed for the 4G TL is 128 mph. True? If so, is there a way around this limitation? Just curious.....
Fastest so far for me was a lil over a buck. Mainly cause my girl was with me. Prly try to hit 120 next time. But in Hawaii theres way too many cars for such a small island so its kinda sketchy. Wanna she what she got tho. Anyone got the Tein Basic Kit on ur TL? Installing mine this week. Hows the ride? Way worse than stock or not too bad?
I've had the 4g to about 120, I hope it doesn't have a limter because that would suck! I raced a G35 a while back with my 06 TL and I finally made it around him and when I looked down it said 155. Not sure how accurate the speedometer is, probably off 5-7 mph, but it was definitely fast.
lol my mom's boyfriend has a fourth generation tl and i own a second generation tl type s and the tl that her boyfriend drives is so fast started on the highway at like 80 K and the second we took off it was gone i think i hit 170 K and it was still pulling away from me lol
have they started making the Type S model for the 4th Gen TL yet or is it in the works still ?
Grandpa
Received 2,609 Likes
The 6-6 chips out at 135.
AZ Community Team
Received 7,771 Likes
I'm betting that at least the AT's are limited.
In the 3G, upto 2006, top speed (I think limited) for either for the AT or MT was ~147 - 150.
However, in 2007, Acura changed the AT to a version based on the RL and limited it to ~132. This is the same limit as the RL. The 2007-2008 MT stayed with a top speed approaching 150.
If the 4G TL, AT trims, are also based off the RL Trans or Trans software, I'm betting they are limited to the same ~132.
The MT OTOH, will probably (based on history) have a higher top speed. Inthe 3G there is some arguemnt as to whether the MT top Speed limit is drag limited or governed. There is a YouTube vid by member fourplay on the Autobahn maxing out and saying that it was maxed due to "fuel cut off".
FWIW, C&D reported that the 6MT was "governor limited" to 134 mph.
I'd guess some of that has to do with Acura's not wanting to have to put Z-rated tires on these cars.
Grandpa
Although you can hit the limit in two places at VIR, I think that it was a logical decision for them to limit the car to 135 in consideration of the typical driver's physical capabilities.
If you want to go faster than 135, I would suggest that you consider doing more to the car than just finding a way to defeat the chip-out governor.
For whatever one stupid old man's opinion is worth, I would leave the governor alone if I were you.
TL Top speed w/video
Alright, so I had to know if it really cut off at 132-135 and yes it does. In th e video you can hear me say fuel cutoff, but actually it's throttle holdback. The computer simply held the throttle so it would not accelerate any more. Sorry for the shaky video, I was using my phone.
The car is very stable at speed and I could cruise 130 mph all day long!
Video WMV file, right mouse click and choose "save target as" It's a little over 8 meg.
Yes, it is fast enough and you don't really need to go any faster, but as a sport sedan with available AWD and Acura touting the handling, if you took it to the track, you would be getting passed down some of the straightaways. Not that I consider a 4000 lb car a "track" car anyhow.
135 is still pretty fast, non sport 3 series can only go 130 & the new SHO is 132
Grandpa
so are you holding the camera in one hand and the wheel in the other?
is this a FWD TL? or the SH-AWD (thought the AWD was some sort of limiting factor w/ the top end?)
and 007Acura - was 130 the limit for the 3G TL-S also?
And yes, FWD TL
Philosophically, only Acura doesn't seem to place a heavy emphasis on aero; Infiniti has "no lift" aerodynamic kits available on their cars and Lexus is always touting sub-0.30 Cds.
Intuitively, the polarizing styling doesn't look like it would produce very good drag numbers and probably has a significant amount of lift at high speeds.
Some time in the wind tunnel or some good CFD is overdue.
Guess we can't have absolutely everything. The limiter should be removeable with tuning, though.
The Germans (even down to Volkswagen) are all Autobahn capable, with great stability at high speeds. The Germans also limit most of their cars to 155 and high-performance variants (AMG, M, S) are usually drag or redline limited.
Grandpa
That doesn't surprise me; I've searched everywhere for the 4G TL's coefficient of drag and can't find it.
It feels like a track car or race car with an aggressive alignment. It just wants to turn very quickly, that's all.
I don't mean to sound like it's dangerous or anything, but I think that Acura did the right thing in limiting the top speed.
AZ Community Team
I'm afraid that I do not know enough to attribute it to aerodynamics, so I will have to yield to your knowledge.
As I posted earlier, the '07/'08 TL/TL-S AT's got a version of the RL Transmission. The RL was already limited to ~132 mph and the '07/'08 TL's has the same limit. Previous to this transmission change the 3G TL was limited at ~150.
The supposition is that the speed limit it realted to the RL derived Trans or Trans software.
Given the 4G uses the same basic AWD system as the RL, I am thinking the Transmissions are related (i.e. the 4G Trans is derived from the RL). Which again allows us to postulate that the speed limit is related to the trans or trans software.
There may be something at Honda News (www.hondanews.com) in the 4G TL Model details that gives additional credence to this suggestion.
The shape of the 4G just doesn't intuitively seem like it would be a lot better than 0.30. But my intuition isn't worth a hill of beans versus a good CFD model or some wind tunnel testing.
I'm Nevadan so I instinctively bristle when someone/thing else "limits" my activities.
Just one more reason for me not to buy this car
then they failed on the design of it (but most likely its the tires they put on it that make it not so good). My 2gtl is rock solid and very easy to drive at 140-150. It doesnt float or wander at all. Wish i could defeat the 149 limiter on it.
Hard to say if it's the tranny or it's programming or a fuel cut off. Looking at the tach in the video the car would continue to accelerate if it was not limited. Another consideration would be the tires. All the 3G sets were W rated for 168 mph which is probably more appropriate to use for 150-155 mph. The 4G models are all V rated for 149 mph so a limit of 130-135 mph is appropriate. The RL and 2G TLS were V rated also.
Acura might have limited the 07-08 3G TL/S, despite the high speed rated tire, just being conservative, maybe due to something in the suspension tuning that they didn't like for those speeds. The 6MT models in the 3G TL and TLS were always tuned a little more favorably for handling and high speed driving. With the tires now being lower rated, both the AT and 6MT 4G models have lower speed thresholds despite the extra tuning that remains in the 6MT.
It seems in the past Acura would limit cars right up to the speed rating of the tire, like in the 2G models. So either they have gone more conservative or there are other reasons such as the tranny or the shorter gearing used in the 4G and 07-08 3G TL/S models.
2010 TL AWD 6MT: New King
The models that exceed 135 mph, are they governed or rev/drag limited?
The reason I ask is because it might make sense to restrict or govern the models that could exceed their tire rating if they were only drag limited but leave the others unrestricted as long as there was enough of a speed rating that exeeds it's top end.
The ECU cuts power by placing a "rev limiter" once you reach the speed programed. In the case of the 04-06TL it was around 155. 2007+ it changed down to around 130-135.
Acura probably reduced the top speed for the same reason most of us are posting here, we are trying to go much faster than we should be going and very few of us know what to do at high speeds when something goes wrong.
If you want to get past it, there are methods, however why would you need to go that fast, even in the quarter mile you won't surpass 110...
Actually i see triple digit speeds very often. At the track (road course not 1/4 mile) And there are plenty of country roads near here that see little to NO traffic that those speeds can be achieved safely. And yes, thats in MPH
