Timing belt kit and strut recommendations.
Had my tires rotated last week and found out they are starting to cup so looking for strut kit ideas for my 12 TL. I am fine keeping stock ride. I found the TRQ kit with all 4 and was also thinking about the KYB GR series I believe? Anyone with experience on these and where to get the KYB with all 4?, I only found sets of two. I also read a couple reviews that some thought TRQ was better on american brand than Japanese branded vehicle?
Also at 117k I need to replace the timing belt. So looking on rockauto at the Ultrapower, Dayco, Gates or SKF kits. They all include the seals. I have a friend from high school who actually worked at SKF till he retired so going to ask him. That kit is the most at $240
Thanks for your suggestions
mdb007 (04-05-2023)
BROlando (04-05-2023)
No problem
Rockauto also sells Aisin blue coolant. You need 2 gallons, and buy a coolant bleeder funnel from somewhere, to make your life 100X easier.
They also carry the OEM Denso Iridium spark plugs, which are due at 105K.
Another item I'd consider doing while you're in there is the oil pump re-seal. I can't recommend any aftermarket gaskets or sealants. So you'll have to shop a honda/acura dealer like hondaautomotiveparts.com or curryacuraparts.com for Hondabond and the necessary gaskets/O-ring seals. Its a lot of additional work...but you're already half way there when you take off the timing components. Look to see if you have any oil seepage near the oil pump. If you do, then research the process.
Use the FSM as a guide.
Available here as a download
https://acurazine.com/forums/4g-tl-2009-2014-123/official-2012-acura-tl-service-manual-956811/
So I assume the Denso 5356 and not the 3483. the first is gapped at .035 second at .044 The owners manual recommends the NGK DILZKR7A11G, any difference other than denso is half the price?
Denso Dxu22hcr-D11s (3483) $16.99
NGK DILZKR7A11G $18.02
I think they are almost the same price. Denso 5356 not fit for 3.5 engines at all.
mdb007 (04-08-2023)
altair47 (04-16-2023)
I just got it the other day. Seems to be solid build quality the bearings are heavy and very smooth but they don't roll freely if you try to spin them, maybe they are supposed to have some tension to them. A friend of mine who is long time tech is going to install for me as he has worked on our cars for years. I just don't feel comfortable doing this. Looking at instructions this kit covers a few different 3.5 engines. I also went with the TRQ complete struts. I think my back LR spring has a little sag to it so figured to just go with complete struts.
And on a side note, when i used to drive 52 miles round trip each way to work the change oil light came on around 7200 miles. but since changing jobs 2 years ago I am driving only 5 miles round trip each day and the computer calculated the oil change at a longer duration. I got 10k miles on this change and I always use the Mobil 1 so I don't worry about the extra mileage and the oil still looked fairly clean.
Oh I never gave feedback on the install. a mechanic friend of mine did the struts and timing belt kit and plugs. The old plugs were shot and that all went well the engine is amazing fast again and it pushes you back in the seat a little under full throttle, never felt that before.
As for the Struts don't go near those TRQ, They seemed like competent struts with a slightly rougher ride. Then in December when the weather in Ohio got around 30 degrees I started hearing a little rub sound from left front, a few days later temps dropped to 16-20 and it sounded like the whole front end was going to fall off. I need to see if if I can get them warranted I thought they had a one year on them.
Also my BT stopped functioning. I found the link about getting a new interface box and installing. then a month ago the drivers window started acting up only going up and down in ½" increments, then the sunroof and front passenger window stopped working but the next day would be fine. Not sure if I have a bad regulator or windows need reset.
FYI my battery died in January and I installed a new Interstate from Costco and it worked ok but died last month because I only drive 2.5 miles to work and it doesnt allow it up to highway speeds, I tested the voltage and comes in at 13.9-14.1 I read sometimes after a battery swap you have to reset windows?
I also bought a 2014 Mustang convertible last summer so my trusty Acura isn't getting driven regular. more trouble shooting to do.
