Switchback with resistors
9th Gear
I tried searching for a DIY but was unsuccessful, anyone can explain to me how i would add the resistors, which wires from the resistor do i clip on to the wire harness on the car?
The inconvenient truth
heres a 4g diy
https://acurazine.com/forums/fourth-...9-11-a-867595/
Just spice the resisters into the ground and turn signal wires. Use a wire tester to figure out which is which
https://acurazine.com/forums/third-g...istors-815219/
have any of you 4Ger's tried replacing the resistor in the relay so as not to add load resistors in the engine bay? Way cleaner/safer.
9th Gear
Ok so I did this and get parking lights work but the the blinkers don’t. Any time I put on the blinkers it blows out the fuse. I connected the resistor and followed every step but I’m still having the problem. The Switchbacks are purchased are these below.
JDM ASTAR Extremely Bright 120-EX Chipsets White/Yellow 3157 3155 3457 4157 Switchback LED Bulbs with Projector For Turn Signal Lights( Only work for standard socket , not for ck socket) https://www.amazon.com/dp/B01CRJR68U/ref=cm_sw_r_cp_api_lru2AbGWV6JCF
JDM ASTAR Extremely Bright 120-EX Chipsets White/Yellow 3157 3155 3457 4157 Switchback LED Bulbs with Projector For Turn Signal Lights( Only work for standard socket , not for ck socket) https://www.amazon.com/dp/B01CRJR68U..._lru2AbGWV6JCF
9th Gear
You sure you did the right wires and got a good connection? Those little clips can suck. I got these ones below and they've worked great for about a year now.
https://www.amazon.ca/JDM-ASTAR-Extr...F9QCGH2T7ZPEXX
I didn't trust the t-taps that came with the resistors so I did a manual splice instead. Have you tried stripping the wires and connecting them together by hand?
9th Gear
I don't think you need the CK ones. Standard 3157 sockets should be fine. I was also deciding between the bulbs you've purchased and these: iBrightstar Newest Super Bright 3157 4157 3155 3457 Switchback LED Bulbs with Projector Replacement for Daytime Running Lights / DRL and Turn Signal Lights,White/Amber https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
jdmjess
12-24-2015 02:03 PM
luder917
04-24-2011 02:59 AM
CLtotheTL32
12-04-2009 01:56 PM
rodneyc77
09-24-2008 07:38 AM
