Steering wheel mounted paddle shifters
I have never had it before. I had something similar on my previous G-35 and SRX (not steering wheel mounted though), but again I only used 1 and 2 gear couple times in snow and to make matter worse I have NEVER driven a manual. Now when I got 1000 km on my TL I would like to try it. I have read a manual, but there is not much there (except when to switch from one to another gear). I will appreciate if someone can briefly explain to me when and how to use it.
Thanks.
Thanks.
The Sicilian
To be honest with you I don't use them that often either. You can upshift & downshift by using the paddle shifters. So when taking off from a stop light the indicator will tell you your in 1 then you just shift up from there. You need to keep an eye on your RPM's if your new at this and really listen to the motor.
They can also be used to downshift as well, just like a manual transmission.
Like I said I don't use them much as I am old school and would rather shift via the gear selector. I've mentioned in previous posts concerning this subject, it feels like your hitting the NOS botton in a Fast & Furious movie.
![what](https://acurazine.com/forums/images/smilies/what.gif)
You can put the shifter into S mode and use the paddles as a manual shifting system. The right side paddle is for up shifting and the lef tside for down. It would help if you had driven a manual so you will know to watch the tach for when to shift.
Also, you can use the paddles in the D more for downshifting to slow down going into a corner or to coast to a stop light....
Just don't forget that you are doning the shifting from that point on. When you stop at a light you will be in first gear again and need to shift to second. If you forget, you'll pull a "Marco" and look like an idiot when your car hits the rev limiter and you can't go any faster.
You can actually use the paddle shifters in both D and S modes.
In D mode, you use it momentarily and then the auto system takes over soon after (so less risk of going into high RPM coz u forgot). I use this to downshift when I want to overtake or whatever, and you don't need to remember to change again after its done.
In S mode, it is completely manual if you use them. So you have to remember to up/down shift when it needs changing. You can disengage the manual mode by shifting to D and then come back to S, if required.
Thanks Guys!
I read the manual again and at what speed gear changes are made but unfortunately more often than not, I keep forgetting to do it . It seems best for me (at least now) to stay on full auto. I also noticed the car picks up speed slower at S mode on highways. I really have to pump the accelerator hard on S6 to get any action on the highway.
In D mode, you use it momentarily and then the auto system takes over soon after (so less risk of going into high RPM coz u forgot). I use this to downshift when I want to overtake or whatever, and you don't need to remember to change again after its done. --- Could you please give me an example. Say I am driving in A mode at 65 km/h (it should be M4 according to a manual) and want to overtake someone. Should I manually go to M3 and then forget about it?
WDP 4G
Paddles and the difference between 2011 5AT and 2012 6AT 1st to 2nd
Accurat - There is no better way to dispel the stresses of the day than by dropping the shifter into "S" and using the paddles to shift manually.
You need to take a leap of faith initially to stsrt to use them. Once you get used to it, it will become 2nd nature. Just like we have all been there when we arrive at our detination on auto pilot, not remembering much of the journey, you will soon be shifting manually without even giving it a 2nd thought.
It is THE best way to enjoy these cars, unless you are lucky enough to own an 6MT of course.
One thing to note, and one that would put me off a 2012 TL, is that the 1st to 2nd shift WILL now occur automatically with the new 6AT. In the 5AT 2009-2011 TL, every shift is under full manual control, in the 2012 6AT, the shift point from 1st to 2nd seems to be linked throttle position, a light throttle will result in a very early shift 2-3K, wheras a full throttle start will result in a 6K+ shift.
Personally I do not like it, it seems to be in all the new 6AT's, my Wife's MDX is the same.
Anybody else care to share thier views on this topic?
not a fan of flappy paddles either. I rather acura's old school Sport Shift with the gear shifter. I hate having both hand at 9/3 all the time LOL. But it makes the driving more fun if you actually use it. I use it sometimes to downshift right before merging/passing and upshift early for fuel economy. It's also helpful if you want to keep a gear, say for racing haha.
rockyboy
08-04-2024 10:35 AM
