Sport Pedals
Old 01-26-2014, 07:15 PM
  #121
gkon's Avatar
Originally Posted by sockpuppet
Is the rubber piece there to separate the aluminum from the steel connector, and fend off galvanic corrosion?
The rubber piece I was referring to was the old brake pedal. Some people keep it on, others take it off. I ended up taking it off to make the pedal fit better, nothing to do with corrosion! I figure if any corrosion happens, I'll just buy some new ones!
Nick
Old 02-16-2014, 12:22 AM
  #122
ffmjst's Avatar
are these hard to install?
Old 02-16-2014, 12:34 AM
  #123
AntSauce's Avatar
As hard as making a peanut butter and jelly sandwich.
Old 02-16-2014, 12:51 AM
  #124
ffmjst's Avatar
out of the 3 which do you think looks the best, the ones with the engraving, the ones with acura written on each one or with acura on one and the acura symbol on the other 2?
Old 02-16-2014, 10:44 AM
  #125
PhantomOfTheAcura's Avatar
Never crossed my mind adding pedals, but thanks to you guys I ordered a set. Looks like a clean setup, cheers.
Old 02-21-2014, 12:18 PM
  #126
damnitzryan's Avatar
Best $27.99 I've ever spent on any car.
Old 02-21-2014, 06:36 PM
  #127
The Original Shawdy
carbonTSEX's Avatar
Is the drilling necessary since you use self tapping screws?
Old 02-21-2014, 06:58 PM
  #128
KarKraze's Avatar
Drilling is necessary on the brake pedal only (bolt and nut is used).
Self tapping screws are used on the dead and accelerator pedals, if you wish you can pre drill those with a smaller drill for easier installation.
carbonTSEX (02-22-2014)
Old 02-24-2014, 02:49 PM
  #129
sehale's Avatar
I bought mine for $28 on Ebay from this seller in China: http://www.ebay.com/itm/140898972612...84.m1439.l2649. Ordered it on 2/17 and it arrived today (2/24). You can see from the photo I didn't get the nice packaging others got but each piece was in its own Ziploc bag and everything was double bubble wrapped in a cushioned envelope. No installation directions. The eBay web site showed installing both the brake and gas pedals with the nuts and bolts but from reading here, I knew just the brake pedal was bolted on. My package of screws, bolts, and rubber washers did not include nuts for the bolts (altho there was one extra of each other item). So I made a trip to Home Depot and bought the nuts for $1.50 (stainless steel). I wrote to the seller and told him but I didn't want to wait another week for him to send me the nuts. Installation was straight forward - had to slightly widen the brake pedal holes as recommended here but everything else was fine. I took my brake pedal rubber off as it was pretty worn anyway. 2010 TL SH AWD.
Old 02-24-2014, 03:08 PM
  #130
ChicofromtheRoc's Avatar
I got Same packege as u. Got all the bolts and nuts but no instroctions and same seller. But that's ok Commen sense is all u need. They look good tho. Can't complaint.
sehale (02-24-2014)
Old 02-24-2014, 03:39 PM
  #131
Filson's Avatar
Going to buy a set tomorrow! thanks for the post!
Old 04-14-2014, 08:42 AM
  #132
Darko
Dgospavi's Avatar
nice… i just picked up a pair
Old 04-14-2014, 11:16 AM
  #133
aIRpeACE's Avatar
will this fit on 3G?
Old 04-14-2014, 02:48 PM
  #134
wreak's Avatar
I had these on my old TSX, they looked great but I won't order them again, once the rubbers became worn down on the pedals they became really slippery in the wet weather.
Old 04-15-2014, 06:24 PM
  #135
Jerry"O"'s Avatar
I also picked up a pair for my 2012 TL SH-AWD. You can't go wrong with spending only $27.99 dollars. They look great!!!!
Old 04-15-2014, 07:16 PM
  #136
AntSauce's Avatar
I've had mine since last August and are still looking great and holding up perfect! If they eventually happen to wear, it'll only cost $27 to get a brand new full set replacement.
Old 04-23-2014, 02:29 PM
  #137
2009 SH-AWD TL
BigDTL's Avatar
Looks really good for the price..Ordered a set today from the link Antsauce posted.
Old 04-24-2014, 01:58 PM
  #138
markwon's Avatar
Wow, these pedals look great!
Old 05-01-2014, 06:04 AM
  #139
Chace's Avatar
Does anyone know if these would fit on a 2013-2014 TL?
Old 06-05-2014, 09:09 PM
  #140
MikeJer's Avatar
I got a set of these that just arrived.
Mine don't have the screw holes lined up in the same places as all the pictures though. My dead pedal piece has only 3 screw holes in it (2 top, 1 bottom-middle). Will this still work, or did I get the wrong part?
The screws in the bag don't appear to line up with the holes in the pedals either. Here's a picture of what arrived in the package:
Old 06-08-2014, 01:45 AM
  #141
MikeJer's Avatar
Well, since no one responded with any advice, I took some initiative and ended up using 3M mounting tape to stick these pedals on. The screw holes just didn't seem to line up correctly. This solution seems to be solid, but time will tell.
Here's the result:
Old 06-08-2014, 07:44 AM
  #142
sehale's Avatar
Here's the result:
For some reason, I could not open either of your pictures. I think the security of the pedals is critical and I wouldn't settle for less than screwing them in. If your pedals look different than the other pictures posted here, I would contact the seller for an exchange. Hope your solution works.
Old 06-08-2014, 04:47 PM
  #143
KarKraze's Avatar
Here's the result:
I cannot open you pic as well,however as the member above said,it is best to screw in the pedals for safety reasons.
I was probably the first person to do this mod and got them from a different source (not ebay),the holes does not have to line up with any existing holes on any pedals.The accelerator and dead pedals will use self tapping screws and the brake pedal needs to be drilled with 4 clearance holes for 6/32 bolt and nuts.
Old 06-09-2014, 08:38 AM
  #144
rock the block
lift3d_'s Avatar
I ordered these last week:
http://www.ebay.com/itm/FREE-SHIPPING-AT-Aluminium-Sports-Foot-Pedal-Rest-Plate-FOR-Acura-TL-TSX-/131209609051?vxp=mtr
thanks for the idea!
SidhuSaaB
05-30-2020 12:40 AM
knight rider
03-04-2016 08:59 AM
xsilverhawkx
10-05-2015 11:00 AM
Quick Reply: Sport Pedals
