Should l I buy ktuner? is it worth it?
Sauce God
If anyone has ktuner with screen for your 4th gen TL SHAWD, Is it worth it? what are some tunes you have? and what can you do ? I just want a crackle tune
I don't have any experience with an actual ktuner but from what I've seen it seems like it'd be something to use for when you install mods on your car to get them running decently enough until you get a dyno tune and also to monitor different sensors while your car is running. I plan on getting one after doing a custom exhaust setup. Also I'm pretty sure that setting a crackle tune would be bad for your engine.
Oh, and I think the v1.2 ktuner is bluetooth so you could just use your phone as the screen and save ~$150 which is the route I'll probably go.
I found this
video on youtube, if you have 30 minutes to spare and are seriously considering buying one I would give it a look. Tells you everything you need to know. Also found this one
thats worth watching too.
I found this https://www.youtube.com/watch?v=8n8r9EEl4zo video on youtube, if you have 30 minutes to spare and are seriously considering buying one I would give it a look. Tells you everything you need to know. Also found this one https://www.youtube.com/watch?v=uF3rDkV0lmk thats worth watching too.
Sauce God
Your joking right? Wasn't your motor the one that burns 5qts of oil in as many weeks? Must be smoking like a forrest fire.
The following 3 users liked this post by 619rcr:
Sauce God
I was being sarcastic brother. I actually recently dropped the transmission to discover a rear main seal leak, and I also changed the pcv valve as well as other good maintenance. I bet my car will run longer and better then yours. I now dont burn or leak at all. in fact I dont think i have filled my oil since that post lol
I also changed the camshafts so i have no damage at all from when I was burning oil
The following 4 users liked this post by 619rcr:
