Po420
Old 06-24-2019 | 06:25 PM
4GTL.chris's Avatar
Po420
I'm trying to just completely do away with my catalytic converters because of the po420 code but I'm stuck between hi flow cats or cat deletes. Any ideas or direction would be much appreciated.
Old 07-11-2019 | 09:52 AM
losiglow's Avatar
This probably doesn't belong in the Car of the Month Showcase.
Either way, if the P0420 code is due to a sensor problem or too rich/lean of a fuel mixture due to some other issue, it's still likely to be there with HFPC's or PCD's. I personally prefer HFPC's (high flow pre-cats) because you don't get the weird exhaust smell, it helps reduce rasp and you can still pass emissions.
Do you know why you have the P0420 code? Do you suspect the stock cats are faulty?
max1995
05-27-2011 11:58 AM
noobiecl
1G CL Problems & Fixes
08-26-2010 11:17 PM
checkmate01
01-06-2009 10:38 PM
RhInoSpOrt
1G TL (1996-1998)
10-11-2006 07:23 PM
em17henry
05-27-2004 03:03 PM
