OEM Oil and Filter
Does anyone run strictly OEM products? I have been running Mobil 1 but am considering making the switch. Thoughts?
Why bother with factory oil? oil is oil. I stick with OEM filter though.
Read that they use a specific blend.
Meh not worth it. I use Mobile 1 Full Synthetic 5w 20 and Honda oil filter and follow the MID (which is already quite conservative..)
(Post 15428974)
Acura does not recommend the use of synthetic oils in models that do not require them as your Acura was designed and engineered based on the oil recommended in your owner's manual. The Acura Maintenance Minder calculates your vehicle's needs based on the oil recommended by the Acura engineers that designed your engine. The use of synthetic oil will not extend the oil change interval |
Originally Posted by SirCarroll
(Post 15428945)
Just as long as you don't put a crappy filter and crappy oil in, you'll be fine! |
M1-104 (S2000) filter + Penzoil Platinum
Buying OEM motor oil doesn't seem necessary at all to me. I am putting in OEM ATF and DPSF fluids though. |
Originally Posted by wreak
(Post 15429352)
Well you shouldn't be...Acura specifically states not to use synthetic oil because the cars engine was engineered to run with a non synthetic blend of oil.
(Post 15429906)
Evidence to substantiate said claim?
^ I concur so that is the reason for my question. I have been running Mobil 1 syn since I got the car. There a some consumption but I don't think it is abnormal. I have read in many threads that consumption ramps up around 50k and I am about 1200 miles away from that. I would like to do whatever I can if anything to prevent having the same issue.
As you have stated it is a "Blend" so it's probably best to use their branded oil. |
Yeah, I'm guessing their business model is to have the car last so long you'll never have to buy another.
(Post 15430078)
I don't think any evidence is necessary when the company that engineered and built the engine is telling you specifically not to run synthetic oil. You could ask Acura directly, I'm sure they'd give you an answer. My guess is when they engineered and built the engine they optimized it to run on their specific blend of oil, not the oil of some random company. They also engineer some of their cars to run on synthetic, so I'd probably listen to what they're saying.
I think this one of those situations where you're taking them a little too literally. 5w20 is 5w20 as long as it is held to the same minimum standards. I think the true test would be to send samples of your oil to BlackStone Labs and have them take a peek at the actual condition of your oil after XXXX miles to see how it's holding up. Given that AZ users have clearly had mixed experiences with different oil brands in burning oil off I don't think anyone can make a blanketed statement of "OEM or bust". |
Originally Posted by TLer trash
(Post 15430429)
Originally Posted by TheMuffinMan
(Post 15430498)
Eh, the only real difference is going to be on some 'high mileage' oils where they have additives that will swell up rubber in effort to prevent leaks.
(Post 15430557)
I'm not saying the engine is going to implode by using non OEM oil, I'm saying they engineered the engine to run with their blend, I don't care what you run for oil. I switched my last Acura to Mobil 1 for a single oil change and the car did nothing but consume oil from that point forward, so I'll personally never do it again.
Royal Purple 10-2867 and Pennzoil Ultra Platinum™ Full Synthetic. Since the 1st oil change to 18k.
(Used the same products on my old 2001 CL type-S until I traded it in at 180k miles) (No problems with oil consumption -always on full however I change it ever 6 months or 6K) (other solid oil filters Amsoil EA15K13 or Mobil M1-110) (Dw-1 Trans Fluid, Amsoil Severe GearŪ 75W-90Transfer Case, DPSF Rear Diff) One day Ill try Redline or Amsoil Signature Series Fuel-Efficient Synthetic Automatic Transmission Fluid Basically the same as TheMuffinman I live in the cold so I always run synthetic and massive Interstate megatron plus battery. Same formula I have used in every car since 84. I have high respect for Amsoil since it was the only manual transmission gear oil that would eliminate the 'scratchy' and tough to shift into 2nd gear when cold on my old 85 RX-7 GSLSE (I tried everything) |
What the 2013 TL SHAWD's owners manual says on
Synthetic Oil You may use a synthetic motor oil if it meets the same requirements given for a conventional motor oil: it displays the API Certification Seal and it is the proper weight. You must follow the oil and filter change intervals shown on the multiinformation display. Basically 5w-20 and look for the starburst (for gasoline engines) My personal view is that I have had more engine issues in the past using regular oil vs synthetic (Not talking about my Acuras). So I am sold on synthetic for like 30 years so I am very bias toward synthetics. I have used Royal Purple HPS, Amsoil, Mobil 1 (almost all formula), Castrol, Pennzoil and Valvoline. My least favorite was Valvoline. I have been very impressed by the newer Pennzoil so much I changed from Mobil-1 I used for 12 years in the old CL. Ultimately I believe it boils down to proper maintenance and intervals. For example, I cannot personally imagine doing oil change and leaving the old filter in and I lean towards slightly lower intervals than recommended. |
(Post 15430078)
Engine oil is one of those subjects that always gets people excited. The truth is, under normal day-to-day use, you could put in any oil and as long as you change it frequently (before it becomes too acidic) then you will be fine. I put in synthetic oil because I like the fact that it retains its properties better under heavy load/high temp conditions. It also has a slightly longer life but I still change it every 5k. I would say, the oil filter is a lot more important than the oil itself. Don't buy Honda filters - they are made by honeywell...the same company that used to make the shitty Frams. Honda also had some nice Filtech filters but they are now gone except for the one for the S2000. My recommendation is...use any oil with viscosity of 5W-20 and a Mobil 1 filter. |
I just can't bring myself to ever use anything with Mobil 1 on it ever again. I had a 2005 TSX, the car ran amazing and never burnt a drop of oil between changes at Acura. I got the oil changed once using Mobil 1 oil and filter and the car burnt oil like crazy after that single change even after switching back to OEM gear. Who knows, maybe it was a complete coincidence, but it was still enough to make me never deviate from OEM Acura stuff again.
(Post 15431072)
Penzoil Amsoil Royal Purple Castrol Valvoline Quaker State RedLine Havoline etc You're going to discredit all of Mobil1 (and an oil but OEM Acura) because of one experience you had in a vehicle you no longer own? Have you read through BITOG at all? Or bothered sending your oil to Blackstone Labs for analysis to see how your oil is actually performing? You've got a very narrow mindset for such a small experience. In my S2000, Mobil1 and Amsoil burned off quicker than Castrol Syntec. So I use Syntec. In my Mazda3 I had, I used Penzoil Platinum due to how well it performed in BITOG tests and from other users' experience with it. I'm going to use PP in the TL unless I see an issue and then will shuffle/change oils accordingly. It's going to blow your mind to know that Acura doesn't make their own oil, it's outsourced/rebranded stuff from Exxon-Mobil. And their filters are Filtech or Toyo-Roki. |
(Post 15431072)
But hey, more power to you man, you're supporting your local dealership so that's great (for them). |
(Post 15433382)
Ok, so how about:
Originally Posted by acupower
(Post 15434913)
Did they switch over to Toyo-Roki recently? Last time I bought a Honda filter from the dealer it was branded as Honeywell.
Found the Honeywell applications here - looks like it replaced the Filtechs/Toyo! Here's the one I know is Filtech/Toyo 15400-PLM-A01 That one lists the 2015 Accord, Civic, CRV, CRZ, Crosstour, and Insight as applications. |
:nod:
A02 is the Honeywell's that have replaced Filtech |
| All times are GMT -5. The time now is 05:24 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
