New Floor Jack Recommendations?
Old Sep 5, 2013 | 06:03 PM
greggw2gs's Avatar
Hi everyone. I am in the market for a new floor jack that can start real low and get it up real fast. Looking for something of quality that will last a long time. Do you have any suggestions? Thanks Gregg
Old Sep 5, 2013 | 06:14 PM
potmilkz's Avatar
my harbor frieght one works wonders.. and for 10 bucks more you get 3 year warranty for leaks.. it came out to be less then $100.. its a very low profile jack as well.. im lowered, maxed out on my tein ss and i am still able to jack it up.
http://www.harborfreight.com/2-ton-l...8050-8048.html
but obviously i got mine at a sale.. you can wait.. for a sale to come through.
i know people will say dont buy HF shit.. but with this jack.. i have good experiences.
Old Sep 5, 2013 | 08:02 PM
BlueAc's Avatar
Acura drove me away too..
Yup... I agree with this. The Harbor Freight jack is a great buy!
Old Sep 5, 2013 | 09:02 PM
Steven Bell's Avatar
Sometimes Costco has basically the same jack for about $99.00.
Old Sep 5, 2013 | 10:06 PM
KrisKasprzak's Avatar
I personally spent a bit more on craftsman--can't remember the price but I didn't want to skimp on something that critical.
ALSO! If you plan on crawling under your car after jacking it up. MAKE SURE YOU USE JACK STANDS!!!! It's way too dangerous to trust a jack, especially if you will be man-handling nut/bolt removal.
Be safe...
Old Sep 5, 2013 | 10:08 PM
MoAbbas's Avatar
moabizzi
Ive had nothing but good experiences with harbor freight stuff. Im not jacking up a car everyday, but i do brakes/rotors , oil changes, tranny drain fill and tire rotations at home for myself and family friends, and the tools i picked up from HF always held up nicely. They also have coupons for 20% - 25% off on a single item, if i get one again, ill post up the code. Also, keep an eye out on slickdeals.net for some jacks, ive seen low profile jacks on sale over there.
Old Sep 5, 2013 | 10:53 PM
CerberusKy's Avatar
Harbor Freight is fine as long as you are not looking for anything the requires precision. A jack is not a precision piece of equipment... I have 2, a 1 ton and a 3 ton. Get the 3 ton when it is on sale.
Old Sep 5, 2013 | 10:57 PM
LaCostaRacer's Avatar
I would go with Costco or Harbor Freight. I have a Costco-source jack that I bought 7 years ago and it works very well and gets pretty low too. With Costco, there is no need to buy any additional warranty since you just take it back and get a new jack. I have never had a problem with a Costco tool but I'm about to return a beach chair that went to crap after 2 years.
I have also bought Harbor Freight tools and they work well too. I use HF torque wrenches and they compare very well with Craftsman. I did have an issue with an Impact driver from Harbor Freight when a bit shattered on me in a middle of a brake job- not cool. With that in mind, I recommend Costco over Harbor Freight.
Old Sep 5, 2013 | 11:36 PM
potmilkz's Avatar
a jack is only to jack up the car.. as long as it does that you are fine... no need to worry about it "falling" because obviously you would not get under a car without jackstands..
no point of dropping 200 bucks for you to only use your jack for a min or two while you put the jack stands up... Pittsburgh works fine.
Old Sep 6, 2013 | 01:26 AM
Kenstlshawd's Avatar
Harbor Freight can be a hit or miss depending on the item. I have 2 jacks from them. One is fine but the other struggle to lift my TL (Yes, the TL is within it rated weight capacity).
If you want the discount coupon just get on their site and have them send you their flyers. You can also find their ad within automotive mags which will also have the coupon.
Old Sep 6, 2013 | 01:57 AM
Jackieee_TL's Avatar
Which jack struggled to lift the TL? I know there "Aluminum Racing" jacks blow, but the "Heavy Duty" ones are pretty durable. They changed the color on them now to that gunmetal brown color in the link Potz posted. They use to be orange back when I picked mines up around 4-5 years ago
Old Sep 6, 2013 | 08:50 AM
It's one of the low profile jack.
Old Sep 6, 2013 | 08:54 AM
thats because the "low pro" ones are rated for a think a ton and a half.
get the "low pro" one that is able to lift 3 tons and you'll raise the car with ease.
Old Sep 6, 2013 | 02:41 PM
MoAbbas's Avatar
moabizzi
81600346
25% off one item at harbor freight.
Old Sep 6, 2013 | 03:43 PM
potmilkz's Avatar
Originally Posted by MoAbbas
81600346
code doesnt work for jacks.. most codes dont work for jacks lol.. they dont let you use discounts for those type of items..
like i said.. get this
http://www.harborfreight.com/2-ton-l...html?hftref=cj
i have it and love it..
Old Sep 6, 2013 | 09:27 PM
MoAbbas's Avatar
moabizzi
http://www.harborfreight.com/3-ton-H...tm_source=1020
Old Sep 8, 2013 | 10:12 AM
Mr Marco's Avatar
Very Important Note:
I have the Craftsman 3-Ton Jack. It is not a low profile, but it does fit under my stock SH-AWD.
The issue I have is trying to get the rear of the car high enough off the ground to get my jack stands under the side of the car.
My Craftsman has a max saddle height of 19.75"
This is not enough.
I would say you need at least 21" Preferably 24" (Like the one Potz has)
The above jack is only good for 20"
Old Sep 8, 2013 | 10:15 PM
wackjum's Avatar
Costco switched out from the Arcan XL325R to the Arcan HJ2500.
The XL325R was, in my opinion, the better jack. All steel construction with a higher minimum (3.75" vs 3.5" of the old) and lower maximum (18.6" vs. 21.375"). The design of the HJ2500 doesn't allow it to get as far under a car either. The advantage of the newer model is that the HJ2500 is partially aluminum and weighs 30 lbs less (60 vs 99).
I bought the HJ2500 today and was comparing it to my XL325R. Kind of a let down but I needed a second jack anyway. Buying at Costco gets you a lifetime warranty.
Old Sep 8, 2013 | 11:07 PM
JnC's Avatar
JnC
Former Sponsor
I like the new HF offering, I have one of the old low profile HF jack and have had it for about 4 years now without any issues.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
JDM96specCTR
Oct 17, 2015 01:06 PM
San Yasin
Sep 29, 2015 10:52 AM
adreano17
Sep 29, 2015 08:48 AM
