New 2009 TL Owner w/a couple of questions
I just purchased an 09 TL this week and I am absolutely loving it! (whenever my wife lets me drive it that is) It has the tech package and we are still trying to figure out what all it can do. It has 32k miles and was most likely leased before we got it. The only thing wrong with it is the front door speakers are blown. I will be upgrading with some aftermarket speaker (probably Infiniti) rather than replace them with the same low quality oem speakers. I have already found some good DIYs on the site.
I was wondering if the vehicle already had it's 30k maintenance done. A quick look at the air filter tells me no.
![](http://i947.photobucket.com/albums/ad318/deermjd/photobucket-5218-1330818595708.jpg)
I looked through the owners manual and it didn't have a whole lot of useful information regarding maintenance. It was basically "take the car to the dealer when the maintenance minder light comes on". So my question is what is the typical 30k maintenace for this car? Anything besides oil change, air filter change, and a good check of everything?
I know everyone likes pictures, so here it is. Sorry for the crappy cell phone pic.
![](http://i947.photobucket.com/albums/ad318/deermjd/2012-02-28_17-42-20_41.jpg)
That's what I thought but I'd rather upgrade the speakers than have them go bad again in another year or two. This is my first Acura and my overall impression is great but it seems likes there's been some problems with theses speakers. It just seems odd since everything else is good quality.
I would get the dealer to replace it first and then upgrade the speakers to whatever you want.
This is the maintenance schedule from the acura owners site found here
Factory Recommended Maintenance:Main Item A
A Plus Service†
Factory Recommended Maintenance:Main Item B/B1
Replace engine oil* and filter.
Rotate tires,** inspect for wear and adjust pressure (2004 & 2005 TL and 2005 RL only).
Service front and rear brakes.
Inspect parking brake adjustments.
Inspect tie rod ends, steering gear box and boots.
Inspect suspension components.
Inspect driveshaft boots.
Inspect brake hoses and lines (including ABS)
Check all fluid levels, condition of fluids and check for leaks.
Inspect exhaust system.
Inspect fuel lines and connections.
Factory Recommended Maintenance:Sub-Item 1
Rotate tires,** inspect for wear and adjust pressure.
Factory Recommended Maintenance:Sub-Item 2
Replace air cleaner element.
Replace dust and pollen filter.
Inspect and adjust drive belt.
Factory Recommended Maintenance:Sub-Item 3
Replace transmission fluid - use only Genuine AFT-Z1
Replace transfer case fluid (SHA-models only)- use Hypoid Gear Oil GL4 or GL5
Factory Recommended Maintenance:Sub-Item 4
Replace spark plugs.
Replace timing belt and inspect water pump (V6 only).
Inspect valve clearance.
Factory Recommended Maintenance:Sub-Item 5
Replace engine coolant.
Factory Recommended Maintenance:Sub-Item 6
Replace rear differential fluid (4WD vehicles).
Notes:
†Includes premium quality 5W20 or 5W30 oil; oil filter and drain plug gasket (if applicable); lubricate all locks and hinges; examination of exterior lights; horn and wipers; coolant, brake & washer fluid check; inspect tires for damage, wear, and check and adjust pressure; and the exterior wash of your vehicle. Price for service may vary. All environmental & waste disposal charges included. If the service indicator does not come on within the year, change your oil every 12 months.
A Plus Service†
Notes:
The Sicilian
I'd have the dealer address all the issues including the speakers. I know the OEM speakers suck, but free is free and when/if they do blow again, then you will have to pay and then you can replace them with the speakers you want. Free is me!!!!
