Missing left license plate light [2010 TL]
I recently purchased a 2010 TL and noticed that the left license plate light assembly is missing. I checked in the bumper area and didn't even notice a connector for the light. The old owner did add backup sensors that beep when you are close to an object. I suspect whoever did the install removed one light and used the power connector for the backup sensors. I plan on ordering a new left license plate light assembly.
Would it be possible to use wiring from the right license plate light to power the left light. If so, what wiring would I need to connect to the power running to the right license plate light. |
3/8/12 here: https://www.oemacuraparts.com/v-2010...l-connector-rr
7/8/9/11 here: https://www.oemacuraparts.com/v-2010...-license-light and yes, no issue you can't tap the right light |
(Post 16943956)
t taps and blade connectors? or two posi-taps should do the trick too
(Post 16943956)
7/8/9/11 here: https://www.oemacuraparts.com/v-2010...-license-light and yes, no issue you can't tap the right light Any idea where I can find the gauge of the wire that goes to the license plate light assembly. I found the part but no reference to the wire size is made. https://www.hondapartsnow.com/genuin...1-sm4-406.html |
| All times are GMT -5. The time now is 11:53 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
