Loose Gasket
Loose Gasket
Just noticed that a gasket is coming out from under the side of my spoiler on my 2010 SH-AWD Tech. Have an appointment with the dealer but wondering if anyone else ever had this problem.
Not sure why any kind of Gasket would be near a spoiler? Is this Front-Rear, Left-Right??? Let us know what they find...
Do you mean the double sided adhesive is coming out? If so, this happened to my decklid spoiler on my 07TL-s and current 2010 SH-AWD. I went to the dealer and they put new double sided adhesive down and now it's fine. It happened to my dad's 07 TL-s as well.
I now have the "gasket" coming out from under my decklid spoiler on my 2010 SH-AWD. I think the hot weather has something to do with it. It seems like it's a rubber material. Service manager said they typically just cut off what's poking out if it's not excessive.
I did a search on the forum and found this thread, so I thought I'd add my experience.
I did as Well!
I took a closer look. It's more like squishy sticky 2-sided foam tape. Could cut through it with my fingernail. I cut off the loop sticking out and tucked the ends under the spoiler. Problem solved.
^ I've had the same issue with mine, at almost the same position as yours...I cut off the protruding adhesive, and I think it's due to the hot weather we have here in Texas. I've done this twice now and now the spoiler seems a bit loose... will address this when I take in for the first service...
ITSJESTER
17
12-06-2018 02:29 AM
InFaMouSLink
10-27-2015 06:52 PM
