Lighting!!!
#42
I am a bullet proof tiger
vleds does offer an h11 in white, however I wanted my fogs to send a projection beam of light vs. Just being bright. I had concerns that an led fog lamp wouldn't serve as a solid lighting option if I encounter fog. However it would be very bright white to look at. Hoen makes really good fog lights so I went that route.
#44
Switch back leds help!
Hey there I just got the Switch Back LEDs Type 2 from V-Leds.. I was wondering where I buy resistors from or what type there are... how much are they? Can I get it locally ? i don't really know that much about it please help if you can..
NY..Acura RL Black 2000. 110miles
also should I keep the top headlights 4300k and foglights 6000k on the bottom ? I got the Xentec 6k's and I dont know if its better quality..? Will it project just as good ?
heres what it looks like - at this moment
http://www.youtube.com/watch?v=T6nDXcHo5DU
#46
i wanna see
post pics i wanna see!!
#47
I got an Acura and i went to Sylvania and I couldnt find the bulb size for my Mirror lights.. what are they called? or can you help me out and tell me what to get at V - Leds? are they License plate
168 bulbs? or Glove box
DE3021 ??
DE3021 ??
#48
Well it looks like you have an RL, so I dont know as I own a TL, but I think its the same bulb for vanity mirrors.
Here is the link.
http://v-leds.com/Interior-LED/Vanit...-p7114848.html
#49
Hey!! I got the Switchbacks Type 2.. So it signals Amber and when the turn signal is off it turns the headlight WHITE.. but the thing is i dont have a resistor . and it blinks FAST. I found one on V LEDS.. is this good for my car? i got the 1157a switchback .. is this the right one to buy? 9005 DRL WIRING HARNESS + RESISTOR ACURA TL RL LEXUS GS300 GS400
#50
the resistors from v-leds are what i used, you need two once for each side of the car. They tap into your turn-signal wires to prevent hyper blinking.
#51
THANKS.. so ill buy two.. but my friend told me my car might need a RELAY ?? "yours didnt then you have to splice wires and soilder a relay to the wires""you need a relay to withstand that power" is the resistor from the link GOOD? ill jus buy two jus let me know thanks!!!!!!!!!!!!!!!!!!!!!
#52
LED's use less power not more. You need a resistor to simulate the power load of the regular filament bulb. You dont need a relay, and the ones v-leds sell are good to go.
#54
I got em done
http://www.youtube.com/watch?v=lDaHKpDVsF8
#56
LED like Audis on my RL ?
Hey this is a Crazy idea I Love it. I want to know what it looks like or looked like.. and btw did you make a Lense for the LEDS/ is it water proof? Im thinking of doing this to my RL 2000 but it might look tacky .. Just wondering.. THANKS!!
I changed my LED Switchbacks type 2.. and the 6000k Fog lights.. THANKS!!! Id like to thank those that help respond on this thread.
Can I buy this LED Strip at amazon and how do I figure out how long each strip is supposed to be. Im guessing you had to cut it ?
http://www.youtube.com/watch?v=MVn-fyC7MH8
#57
yeah I know that but I was wondering is my blinker ok for now and driveable around areas? I don't like driving thinking that i'll get pulled over for my blinker going a tad faster then usual.
#58
hoen 9005 for DRL/High Beam
So I made a mistake ordering 9005 SMD which should be arriving soon to replace my 9005 DRL/High Beam. Anyway, will the 9005 Hoen xenonmatch works to replace the stock? Will that give me the white colored DRL that I'm looking for?
thanks!
thanks!
#59
Yep, but get the Xenonmatch Plus, not the regular. They're 65W and designed for this purpose. They illuminate white when in DRL mode.
#61
I have the Xenonmatch Plus for my DRL's. It's slightly whiter than stock but still pretty yellow. If you want completely white, I think the only route to go is HID's. (I've tried LED's but they suck output-wise)
#62
TL-SHAWD 6MT Rocks!
Nice job! I love the idea of adding some LED's to the TL,
although I think we should use the wonderful lines of the car...
If you look at the Audi, the LED's are not perfectly level, they have an incline, so I copied those LED's and added them to your TL picture to see how they would look... (sorry for my lack of photo skills) I hope you get the idea.... doesn't it looks 100% better ?
http://picasaweb.google.com/lh/photo...eat=directlink
image not showing here, don't know why...
#63
TL-SHAWD 6MT Rocks!
[quote=NOX 3.2;11424434]Nice job! I love the idea of adding some LED's to the TL,
#64
[QUOTE=NOX 3.2;11424463]
Those do look good, the only thing with the audi, MB, and porsche LED's is they're hella expenisve. They are like $50 a bulb. So it adds up very fast, hence why it doesn't come standard on all their vehicles and you have to get a special package on cars like the e-class and the a4 to get it. But it does look good
#69
TL-SHAWD 6MT Rocks!
I found a place where they sell the LED flexible strips you can add to your bumper of lights, to look similar to the Audi's DRL
http://store.ijdmtoy.com/JDM-Luxer1-...Lights-s/3.htm
#70
Former Sponsor
Non of the LED strips offered on the market compare to the Audi DRLs. Audi DRLs are high powered SMTs with proper heat sinks and circuitry. Even the color is not the same, strips have a ricey blue hue to them where as the Audi DRLs are neutral white and are very very bright. Here are some pictures, this DRL is from Audi S6 and by no means its small, the floor tile is 12"X12" to put it in perspective.
#71
2009 ACURA TL
Low beam headlamp
HID-D2S
High beam headlamp
9005
Parking light
1157A
Front turn signal
1157A
Rear turn signal
992 (7440A)
Tail light
LED
Stop light
LED
High mount stop light
Assembly
Fog/Driving light
H11
License plate
168
Back up light
921
Front sidemarker
168
Rear sidemarker
168
Step/Courtesy light
158
Trunk/Cargo area
168
Daytime running light
9005
Those are the replacement bulb numbers for the 09 TL. If your talking about the front turn signal next to the fog lights, I have changed mine out to Led switchbacks, so they run white when the lights are on, and switch to amber when you signal. You can get these on V-Leds.com. If you change the turn signal bulbs to LED you will have to install resistors to avoid hyperblinking, do a search there are a few DIY on here. I am not sure about changing out the DRL's, I was interested in this as well, but almost everything I read in different threads people were having issues with the DRL warning light coming on.
Low beam headlamp
HID-D2S
High beam headlamp
9005
Parking light
1157A
Front turn signal
1157A
Rear turn signal
992 (7440A)
Tail light
LED
Stop light
LED
Assembly
Fog/Driving light
H11
License plate
168
Back up light
921
Front sidemarker
168
Rear sidemarker
168
Step/Courtesy light
158
Trunk/Cargo area
168
9005
I have been researching how to replace my high beam/DRL with HID for quite a while. Some people are saying this is not doable. So, my questions are:
1. There is really no way to do this? if there is, how many bulbs do I need? which brand would you recommend?
2. I don't think I can do the installation by myself. So, is there any reliable auto shop would you recommend that can do this? how about Midas? I asked Acura dealer. basically, they will not do this kind of aftermarket installation.
3. how much would this cost?
Thank you very much. I appreciate it!
#72
Hi,
Hope this helps
#75
I just want my 2010 to have the same Bi-Xenon headlights that my recently (and dearly) departed '07 Type-S had. Any chance that those lights can be adapted to my breath-taking Mayan Bronze, MT, HPT (picked up yesterday--oh MAN!)?
#76
OK, all this talk of LED upgrades bit me and I've just ordered up V-LED's replacement bulbs for my 2009 TL's vanity mirror lights (4), driver's door puddle lights, trunk and license plate.
Now to the two other upgrades that there seems to be a bunch of discussions spread over a variety of threads.....Fog light change to get a better color match to the OEM HID color and then the High Beam change and problems with the Daytime Running Lights.
On the Fogs, many threads say LED's give the color but lack the punch...so why not just change out the bulbs to Sylvania SilverStart Ultra High Performence H11 Halogen in the 4100k color range. The color rending chart for the Sylvania halogens is here.
On the Daytime Running Lights & High Beams.....why not just change to Sylvania 9005SU SilverStar Ultra High Performance Halogens which would be a plug-in to std OEM wiring with no other changes needed.....color rendering is 4100k and that should be close to std. OEM HID low beams (correct?). The DRL would be cooler color and should still work since they are really the high beams running at 50 power.
Doing the two above changes when staying with the stock OEM HID low beams seems like it would give the best color match and performance. Any ideas to the contrary or confirmation from someone who already tried this?
#77
ghanner, I agree with what you are saying above, with the 9005SU. I think this was a topic of discussion between us in another post somewhere. I do believe that I am going to go with 5K HID fogs and replace the OEM HID low beams with the 5K HID bulbs, just because it is a more intense white, then with the highs, I will go with the 9005SU, it will almost match the rest, and it is easily doable and to top it all off, 5K switchbacks. The only thing I am still fuzzy on, are these resistors for the switchbacks, where do I install them at?
Is it just as simple as swapping low beam HID bulbs to change colors? As they are already HID, or is it the whole ballast system that needs to be changed?
#78
I'm not sold on the switchback change yet...since on my SH-AWD it would like like I have 2 sets of fog lights. I kind of like the amber color down low adjacent to the fog lights at this point. The resistor is needed to replicated the higher load that a filament bulb would have. Exact placement of the resistor and which wires you have to tap on left and right side is in this thread here.
#80
Are 168 and 158 LEDs the same? I'm trying to order replacement bulbs for my rear license plate (168) and courtesy/step lights (158).
I'm looking at these: http://www.v-leds.com/2-hid-white-5k...4-168-158.html
