Left Turn Signal
Old 12-10-2018, 05:31 PM
3rd Gear
Philip Geppi's Avatar
Left Turn Signal
I bought a 2009 Acura TL three years ago and it was in perfect condition with only 22000 miles on it. The only issue it had was that it was in for maintenance for an unknown blinker issue. Fast forward to present day, whatever they did to fix it has returned. The left turn signal sometimes will work and sometimes will not. If I turn the steering wheel all the way to the right, you will hear the normal audible clicking. Sometimes when it is not working, you will see the lights blinking as normal but you will hear no audible clicking or you will hear the rapid audible clicking. I have since switched out the turn signal module, but it did not fix it. Any help is greatly appreciated because I am clueless at this point. Thanks
Old 12-10-2018, 05:41 PM
Received 8,693 Likes on 6,707 Posts
Have you changed the bulb?
Old 12-10-2018, 05:47 PM
3rd Gear
I honestly have not because all of the bulbs are working. None of them are burned out. FYI, the tight turn signal works perfectly. And for some reason, like previously mentioned, the left turn signal will at random begin working again.
Old 12-10-2018, 05:59 PM
The turn signal bulb is dual filament so one could be out but not the other.
If you're having an issues with the turn signal, the first thing I would look to replace is the bulb itself before tackling the turn signal relay and potentially the clock spring or turn signal stalk..
Old 12-10-2018, 06:18 PM
3rd Gear
All right that's what I will do when I will check back. Thanks.
parivera30
4G TL Problems & Fixes
02-15-2009 10:08 PM
DANMAN421
01-15-2008 07:41 AM
darrinb
07-23-2004 07:42 PM
Quick Reply: Left Turn Signal
