LED License plate light
#41
I knew that was going too smoothly.
seems like one of the 4 bulbs is defective... it's very dim compared to the other 3. I'm assuming it's defective and I need to contact iJDM... but before I do that I should probably test one of the other 4 functional bulbs in the same driver side door which is lighting it up extremely dim (cant even tell it's on).
if you are going to change the courtesy door light blubs gently pri(spell check) the black holder that holds the bulb out gently and the entire fixture will come down with the wiring then you can unclip and remove lens and grey cover assembly and replace your bulbs correctly and fasten them correctly and do the reverse to reinstall be sure to be gently because the grey liner has some teeth that grabs onto the black assembly and you do not want to break those eventhough its not a big deal if you break a tooth just becareful do it as a certified acura tech would. Overall this is the best way imo verses removing the lens only I was trying to change my bulbs but the wiring is bad anyone knows where the harness or source to make the assembly works again ive been searching since june no threads. took it to the dealer and they need $122.00 for a diagnose check im outside warranty.. but if anyone change through me something on here that would be great
#42
Unique Style Racing (USR): High-Power SMD T10 White LED Bulbs for LED License Lights
Hi Everyone,
We would like to offer ONE person who will purchase a set first from us for the latest Canbus Version of T10 High-Power White LED bulbs to fit onto your Acura TL's license and once clean installed photos are provided, we will offer full refund.
If you are interested, please PM or reply this post to reserve the spot. And if you are in So. Cal, you are also welcome to schedule with us to come by for installation and get a set for FREE, that way no purchase needed.
Thanks.
Best Regards,
Thanks.
Best Regards,
#43
Hi Everyone,
Thanks.
Best Regards,
Thanks.
Best Regards,
DIBS! 100% interested
#45
#47
these bulbs look great on the license plate - but total shit on the under-door puddle lights. Cant even tell they're on. I'm wondering if I need clear lenses or something
#49
#51
I just bought these bulbs from USR and i couldn't be happier
https://www.uniquestyleracings.com/i...=acura+license
They only cost $12.95 shipped. Plug and play no modifications needed (you might need to turn them 180 degrees as they only work one way but will fit both ways). Produce a nice bright pure white light. Feel free to ask me any questions.
Before
After
Before
After
#52
#55
Link and night picture would be legit. Can't go wrong with Vleds. Local for me too. I got a pair of their cheapest ones for free at a car show and they've been going strong for 3 years with no flickering or going out. Bought to take them out of my TSX and install them in the TL.
Silvermoon_Knight
10-22-2015 06:25 PM
oyayjoe
09-12-2015 04:40 PM
darksky
09-05-2015 03:11 AM
