LED Headlights or White Bulbs?
Do you think it's a better route to go with aftermarket LED headlights or just put in white bulbs to get rid of those yellow stockers?
Has anybody done this? If so, please post pictures or links. Also it would be helpful to know what is the stock bulb size and what can it be replaced with (white bulb)
Thank you!
Thank you!
When you say ‘headlights’ do you mean low beams or the DRL/high beam lights? I have VLED 6k DRL/high beams on my car. Some people have gone for the 5k’s too, so that they’re a closer match to the stock low beam HIDs.
Are the low beams already white? Sorry, im new to Acura. Just bought my 2010 TL 2 days ago.
So the VLED 6K, where did you get it from?
Personally I have OSRAM CBI HIDs, VLED 6k switchbacks (Triton v6s)/DRLs and Hoen Endurance 3k fogs in the front. I’d go with a 5k or 6k setup all the way around if I were you. 5k = slightly yellow & 6k = slightly blue
If you have large hands take the time to note the orientation of the bulbs tabs when you pull them out. (High beams). One side is the fluid over flow and other side is the battery.
D2S -Low beam (I had to take off the bumper to get at the passenger D2S - that one just sucked with large hands and arms.
9005 (HB3) - High Beam
H11 - Fogs
I have come across some fake bulbs on Amazon.
CARID or https://www.theretrofitsource.com/ if I am looking for something for sure.
One I am going to test out is http://store.ijdmtoy.com/9005-CREE-H...l.htm?CartID=1 with R2 decoder.
H11 - Fogs
Ive gone down both roads. If you go LED, heres a list of if you want to replace EVERY build in ur car to be LED.
They are the BEST on the market, with BUILT IN decoders so no flicker, etc. No having to drill extra pieces or decoders or anything. PLUG and play. for real.
https://www.carid.com/cart.php?utm_source=email&utm_medium=lead
Halogen bulbs that is the closest to white youll get. It functions just as your Stock bulbs do, just at about 5000k which is a overall whiter light and the highbeams get brighter...
Its not as white as LED but its not yellow thats for sure.
http://www.philipsxenon.com/acura-c-333/philips-diamond-vision-5000k-ultimate-white-halogen-bulbs-p-1300.html
My bad, here it is again
https://carid.com/cart.php?rst_cart=...tm_medium=lead
Now remember This brand is PREMIUM. You dont need to buy ANYTHING additional. The bulbs have BUILT IN decoders which prevent flickering and error codes.
The challenge you will find is that there is not an LED bulb at this time that will give you low voltage for DRL and high voltage for HIGH BEAMS for our cars. Its one or the other.
yes
Follow this link, it incliudes EVERY bulb for your car.
XenonDepot | 2012 Acura TL HID Kits | Replacement Bulbs | LED Lighting
echodigital (03-20-2018)
Keeping TL until 2029
I used Putco bulbs LED with ribbon heat sinks. No moving parts so it should last forever. LEDs are the way to go.
https://acurazine.com/forums/fourth-...pgrade-953482/
That's what I did. The 6000K bulbs from JDMToy only lasted a couple years (one of them, at least). After chatting with a guy that sells all sorts of bulbs (same guy I bought the Morimoto fogs for the wife's pilot...wish they made 'em for '09 TL's) I went back to the OEM 4300K, and them replaced the highs with high quality halogens. They don't match perfectly, but are pretty close (more than close enough, in my view. And going back to the Philips HID's was definitely the right decision for me.
....Still chuckling...
yeah - I went ALL LED except for the DRLS...Those are the 5000k Philips...im pleased.
A few reason:
• No LED DRL will behave the way Our stock halogen bulbds DO, I mean If they work as DRL they will not get brighter as High beams when Switched on.
• IF you get the ones that work Ultra BRight as HIgh Beams, They wont work as DRLs
• The fact that you have to Drill holes in the engine bay area to mount a error code thingy cause it gets so hot it cant dangle.
IVe looked ALL Over for An LED thats Bright White as A DRL (ON OUR SPECIFIC CAR) and will get BRighter as we turn on high beams.
So, there ya have it. I went with LD On all the others Because the brand is Trust, SUPER quality and they were affordable. ANd they had the decoder Built into the bulb. No extra pieces.
WHen you get time, PLease upload a pic...Id love to see them as HIgh BEam and as DRL...If the technology now Exist I may switch over
The inconvenient truth
The technology exists question is how reliable they will be. The ones I had have 3 chips in them. 1 chip lit up in drl mode and all 3 lit up for high beam. Granted they stopped working after 2 months but I got my money back and am tempted give them another shot since they were so awesome.
high beam
drl mode
high beam
drl mode
high beam
drl mode
I bought through amazon these ones here
Also needed these resisters
No need to drill, what I usually do is tuck the resisters away somewhere they wont move or sometimes ill hold them in place with two sided tape. I think you can get ones with built in resisters also.
But again they did stop working on me after two months and the seller was a twat, I had to contact amazon directly to get a refund. I would recommend not buying from 'LED EAGLE' and instead trying a comparable product from another brand. That's what I'm going to do when I have time to surf around amazon again.
https://www.amazon.ca/LED-EAGLE-Canceller-Capacitor-2009-2018/dp/B072QCBQSM/ref=pd_sbs_263_7?_encoding=UTF8&psc=1&refRID=KQGSX8SJKFGVZAJBJC4X
https://www.amazon.ca/dp/B071KFF96J?...a-c570-20&th=1
https://www.amazon.ca/LED-EAGLE-Canceller-Capacitor-2009-2018/dp/B072QCBQSM/ref=pd_sbs_263_7?_encoding=UTF8&psc=1&refRID=KQGSX 8SJKFGVZAJBJC4X
