LED DRLs - Build My Own Decoder
Old Nov 10, 2012 | 05:00 PM
tal0s's Avatar
3rd Gear
I have a 2010 Acura TL, and I want to install LED DRLs.
I have extensively read and do understand the principals of DRL errors and modules/decoders to correct.
I am looking for a diagram of the DRL system for 2009+ TL
or
Information on how to create my own harness with 25 ohm 25 watt load resistors and a 12V relay.
I found a diagram in the 3rd gen section, but I seem to recall reading the 2009+ are wired differently.
Thanks in advance for the help
-T
Old Nov 10, 2012 | 05:06 PM
tal0s's Avatar
3rd Gear
Here is third gen diagram - is 2009+ different?
Old Nov 10, 2012 | 07:53 PM
potmilkz's Avatar
so this is a diagram to run your DRL on full power?
Old Nov 10, 2012 | 08:10 PM
Edward'TLS's Avatar
6G TLX-S
I don't quite understand the above 3G diagram.
How is the 12V relay switched ? What gets connected to what when the relay is switched to either position ?
Old Nov 10, 2012 | 08:31 PM
potmilkz's Avatar
yea.. i see no purpose of a relay.. just install resistors
Old Nov 10, 2012 | 10:00 PM
tal0s's Avatar
3rd Gear
Yes, the relay is there to run the lights at full power.
The apparent hurdle I found was using 6v+ from DRL circuit will not hold relay open.
I believe there are a couple of methods used to step up voltage, however, I decided to install the lights without using the relay. I decided they are bright enough for my taste.
I noticed the DRL error, and installed a 6 ohm 25 watt resistor in parallel behind each plug. This eliminated the error.
Thank you guys for the responses. I hope others will find this post and realize no special decoder is necessary.
-T
Meant to say,
The 6v+ is not enough voltage to keep contact closed.
Old Nov 10, 2012 | 11:57 PM
potmilkz's Avatar
um.. glad you went that way.. as you know if you use your method you will completely loose the function of highbeams as it no longer exist.. which to me sounds pointless.
run the resistors, and let it run at 30% its fine, i have it, some of the members have it.. so it should be fine.
Old Nov 11, 2012 | 02:43 AM
KB1Spec's Avatar
09-11 set up is fine on the diagram. 12 set up is totally different.
Old Nov 11, 2012 | 12:07 PM
Edward'TLS's Avatar
6G TLX-S
I guess you fully understand the above 3G connection diagram.
Don't worry about the '12 setup for now.
Let say for the '09-'11 setup, what gets connected to what when the relay is (1) open and (2) close ?
Old Nov 11, 2012 | 12:56 PM
KB1Spec's Avatar
I will need to check. As I know the 09-11 and 12 set up is different. I have a 12 and the LED DRL only works for that 12 up and not workable for 09-11. I've tested them out and didnt work on the 09-11. I will check on the wiring for the 09-11 at my friend place.
Old Nov 11, 2012 | 04:54 PM
Edward'TLS's Avatar
6G TLX-S
No need for all that trouble. I'm just question the validity of the 3G connection diagram in post#2 above. It doesn't look like it will work properly at all.
Old Nov 11, 2012 | 08:13 PM
Mr Marco's Avatar
It makes the car FEEL faster.
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
Sarlacc
Console & Computer Gaming
Sep 30, 2015 02:15 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
greeneyes.hypnotize
Sep 27, 2015 02:47 PM
eastcoastguy
Sep 23, 2015 06:29 AM
