Just bought a 2010 AWD-Tech and need your advise
Hello everyone,
I am new to the forum and to the Acura brand. As the title read, I bought my first Acura (2010 TL AWD-Tech. automatic) with 38K miles two weeks ago.
I went through enough posts to figure out the major issues for this model and I can live with it except for the torque converter and the stiff ride. I need your advise to decide whether I keep the car or cut my loses and get rid of it.
Is it normal that the downshifts hold the car back as if the brake was applied? In other words, when I get to certain speed and then lift my foot and the car slows down gradually, I can feel the car downshifting harsh (kind of) as if someone applied the brake momentarily during the downshift and the same happens with next downshift as the car gets slower and slower. This particularly annoying if i am braking and the car brakes even more with the downshifts. It is impossible to have smooth braking no matter how I try to adjust my braking pressure.
Is this related to the torque converter issue? I took the car to the dealer and they claim that the technician couldn't find anything wrong with it and while the converter is not replaced under the extended warranty (expired 8 month ago), the software, supposedly, is up to date.
Your help is highly appreciated.
The inconvenient truth
when was the transmission fluid changed last?
I'd do a drain and refill of the fluid anyway. It's pretty easy to do yourself. Or you can have the dealer do it. They'll charge upwards of $120 or so. You can do it for about $30 (just the cost of the fluid).
But yeah, I'd say that I notice the downshifts a bit more on this car than on other auto's I've driven. Granted, I have a 2012 FWD which has a different transmission and drivetrain so it's not really apples to apples. It's not overly obtrusive IMO but it's definitely more noticeable.
I live in an apartment complex and it is not easy to do the fluids by myself (even though I am very handy). I think it is better to have the dealer do it (at least the trans fluid) so it can be documented in case I try to get Acura to cover the converter under the extended warranty if needed. I will get a quote for the full flush (all fluids) and partial flush (trans. only) and report back.
Thanks for the feeds back and suggestions
If you don't know when the transmission fluid was changed last then just get that done and it might make a big difference. Make sure not to 'flush' the transmission though, only drain and fill.
Thanks. It looks like a fluid drain and fill is highly recommended in my situation. I will try to get it done over the weekend. Any thread you can point me to for a DIY instructions to see if I have what it takes to do it or have the dealer do it (for documentation mainly).
Here are a few transmission-related links from the How-Tos section at the top of the page: Acura TL 4th Gen Transmission Guides
Let us know if it makes a difference.
Good luck!
basharalshamma (10-02-2018)
Thanks for the link and wishes. I will definitely update the post after the weekend.
My plan was to keep this car till 150-160K (with minimal/regular maintenance) but after driving it for the past couple of weeks, I doubt this car is the one to keep. I am trying my best to isolate actual issues from normal behavior before I make my decision as I really love everything else about it.
The other issue is the stiff ride. I know the TL should be stiffer than the average car but this car is too harsh/stiff (The 18's only add to the problem). I am starting to feel as if an aftermarket springs/shocks are installed instead of the factory ones. I am not sure if it is easy to figure out by visual inspection but I will try to get some info about the suspension.
SH-AWD TL's do have stiff suspensions. Probably stiffer than you are used to. Its good because it helps them corner like a mofo with the sh-awd but not so great for ride quality. Also the tires can factor into it as well. But it really, really sounds like you would have benefited from test driving the car before purchasing.
I don't know if my words make sense but I think the picture is clearer about what I meant by the stiff suspension.
If I keep the car, I will definitely invest in a more economical solution. I know many members do trans. fluid drain every other oil change.
Do you guys recommend doing the brake fluid too (around $150)? I know the manual recommends it every three years regardless of the mileage.
Regards,
mobfunk
10-30-2019 12:45 PM
sigmachikansas
05-19-2011 09:06 AM
rocketguy
04-20-2010 08:14 PM
