Improve MPG's?
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
I've been noticing my car has been getting 14.1 MPG for the past 6 months
I don't do highway driving, mostly suburbs with only 5 traffic lights in a 5 mile stretch
All 4 tires are like new, always at 32PSI
Is this normal or do I have a faulty sensor? O2? PCV?
That's exceptionally low. The car will do worse on winter fuel and if you live in a place that gets cold in winter, but the worse I've ever seen in continuous stop and go traffic is about 18 mpg. Something is wrong, assuming the calculations are correct.
Since the torque converter recall software update I have been averaging 13-14MPG year round on a similar commute (I use Gas Cubby). Ive been to several dealers, had the car checked out multiple times, and even opened a case with ACR and they all believe my MPG is normal based on the new shifting program. Pisses me off, but I have been unable to find anything else to do short of getting a new car.
I'll have to look at my car, but in my other vehicles that wasn't the most reliable source. Better than going "I get 200 miles per half tank, I used to get 300!" but not quite as accurate as resetting the trip meter and dividing that by the gallons you fill the car up with.
exactly same here
that is my almost all city drive mpg 14 15 heavy throttle foot
highway is 20 to best case 24
Drei, if it's dry you can check with a local tire guy and see if you should try a higher psi. In dry SoCal with the OEM tires I normally run 40 psi. It makes the ride a little rougher but you mpg should dramatically improve.
Davensd
Davensd
Here's one other thought. If you keep the HVAC on "Auto" setting, the A/C comes on quite a bit to reduce cabin humidity, even if it's not warm outside. When outdoor temps are not warm, I manually turn the A/C off to stop this. The cabin feels very comfortable, but I think it helps a couple of MPG, especially in stop and go driving. I
You're right, I just ordered this kit that includes both the engine and cabin filter
2009 2010 2011 2012 2013 2014 Acura TL Engine Air A C Cabin Filter Kit New | eBay
On the cabin filter, I am liking
Mann Filter MCF 1008 Cabin Air Filter with Polyphenol Layer
One note on the cabin filter - make sure you get the edges of media pinched into the slots on the 2 sides. Seen too many times where the filter is just thrown in willy nilly
On a personal note: I am dreading carrying my summer tires and rims down 3 flights of stairs...at least the winter tires and rims are hell of lot lighter
I have been getting crappy fuel economy too! Almost all winter it has been 13-15L/100KM. I live in Ontario, Canada so I do experience pretty cold winters. Also 95% of my driving is city. Cold weather and no remote start makes for warming up the car for a 12 minute drive very troublesome. My temp control is also set to Auto... I will see if it improves when temperatures improve.
I have similar commute of about 5-7 miles, with 8-9 traffic lights, and 3-4 stop signs. I get about 14 - 15 mpg, so very similar. Asked dealer couple times, and he says that is normal with the commute I have.
I need to change the air filter to see if that helps.
I was getting around 17mpg and have always thought the miles counter on our cars was not always rite. a few weeks ago i reset the ecu (Ktuner) back to factory and took off Neg bat cable and it reset the MPG on both A & B.
Now i'm averaging 29.5 hwy and 17 city on my last 2 fillups.
don't know if this helps but just my 2 cents.
OculiAquilae
15
02-26-2016 02:11 PM
