HOW-TO: wire fog lights so they can be turned on/off without having the headlights on
Hey guys!!
Just as the title says, I’m looking to turn my OEM fog lights on/off using the OEM factory stalk (switch for fog lights) WITHOUT my headlamps being turned on. The only
way my OEM fogs turn on, is if the headlights are on. I want to be able to turn them on/off whenever I want. I’m fully capable of doing the mod. I have done the mod on several cars in the past.
I just need the wiring diagram. (or relay diagram)
I found a few threads to add an aftermarket or Accord switch. But that’s not the route I want to go.
There was a thread that an MDX owner did this exact wiring mod and mentioned it was similar on the TL SH-AWD.
So far I have searched and have had no luck finding the simple wire diagram on how change the trigger(power) wire for the fog lights, from the headlight control, to being controlled independently through the fog light switch.
I hope someone understands what I’m trying to accomplish. Lol!! Thanks in advance guys.
I really appreciate your time.
Thanks @Thoiboi for the quick response.
This is the mod I’m looking to do.
However, the thread you posted was for 3rdGen TL.
Do you happen to know if it’s the exact same
as the 4thGen TL? I’d assume not, but if so
That’s great.
Thanks again guys😎🤘🏽
That’s great.
