How $5 accsesory turned into nghtmare
How $5 accessory turned into nightmare
Hello everybody,
Just want to share and at the same time warn you against using non OEM aftermarket air valve caps. I purchased a set from Ebay made by TVG Mfg.
When I tried to remove them to refill air into my tires they broke the air stem/valve so now I have to replace whole tire pressure monitoring sensor. I was so stupid that I broke 3 out of four.
I patched hissing valves somehow and drove rapidly to nearest tire shop . They could not order any 2010 Acura TL original ones in stock so I asked them to put regular rubber stems without tpms.
Today I already ordered 3 OEM sensors.
Where should I have it installed? Dealership or regular tire shop? Do I need to program it? I know I have to buy new washer, seal etc...
Here is the link to picture: http://www.flickr.com/photos/7278182...57636772139716
I already calculated that this $5 mistake gonna cost me $300
![omg](https://acurazine.com/forums/images/smilies/omg.gif)
^^ Well, at least you have a valuable lesson....trying to save money can actually cost you more money!!
That being said, once your OEM valve arrive, you can take them to either the dealer or a reputable tire place. Myself, when it comes to tire, the dealer is not always the best place to go but make sure that wherever you decide to go, that you ask them to be careful about removing the tires off the rims and not do any more damage.
As far as the OEM TPMS...they are self locating but I think the initial install needs to get them programmed. Once they are programmed, you can rotate the tires and such and they will self locate.
Either the dealer or a good tire shop will enable the TPMS and shouldn't be any problems.
Keep us posted and best of luck....
so why did you want to use non-oem valve caps? is it because they look cool?
i see no point of changing the oem caps to anything else but oem stuff..
justnspace (10-21-2013)
heat shrinks metal,, so if you attempted to take the valve stems off right after you drove the car.. it can be a problem.. shrinking metal + threads do not work well..
Especially with cheap caps made from god knows what with shitty threads. Lesson learned the hard way on this one.
Received 6,470 Likes
Sorry Kurt....
LOL...I think you may have missed a few days of science class. Heat expands metal as its atoms gain more kinetic energy. Your theory is false.
IBankMouse
06-13-2020 12:53 PM
SidhuSaaB
05-30-2020 12:40 AM
