HID Fog Lights Too Much Glare?
I'm considering upgrading my fog lights to HID H11s. However, the fog light housing is a reflector housing, which may cause massive glare (Think those big trucks you see on the freeway behind you with those annoying blue HID head lights and fog lights that look like a massive blob of light).
I certainly don't want to be blinding/causing glare to the driver's in front of me. Also, don't want oncoming traffic to be blinded either. For those who have HID fog lights, have you had anyone tell you that your fog lights are causing too much glare and are annoying? Anybody facing you (say at a four way traffic light) flash their high beams at you because they are being blinded with your HID fog lights?
to be truthfully honest, your low beam hids are just as bright as if you put HID fog lights.. its the same.
the reason why TRUCK HID are glaring is because they are high and they do not have projectors for low beams.
its fine with HID fogs.. many people in SOCAL does this and its not a bother
I have car ADD
yea, i agree....i've put HID fogs in my last 2 TL's with no problems what so ever...
No excessive glare, or blinding... and they are still pointed downwards. like he said above, the obnoxious lights you see, is when somebody drops an HID kit in their halogen headlight housing.. without adding a projector to help dissipate the light
just make sure you get a 35W kit, and install relays... and you shoudnt have any problems
Thanks for the response. But our fog light housing are also non-projector housing. But if I'm understanding correctly, you guys are saying that's okay, since the fog lights point down.
Do you guys think that the HID fog lights light up the road better then stock? Right now, I can barely tell that my stock lights fog lights are on. I turn them on and off at night on a dark street and barely see the extra light output from them.
i have hid fogs on my tsx...they definitely do add some light to the road, but not a tremendous amount. It will be noticeable to you when you shut them off though. I have noticed that i see the biggest decrease in light on my peripherals when i shut off my fogs which makes sense considering they are in a reflector housing and bleeding some light on all sides
I question the value in switching to HID fogs when there are simpler plug & play halogen solutions using Sylvania 4100k Ultra bulbs (that K figure is off the top of my head) which should be a good color match with the OEM HID.
sorry to be a hater man but i went through the whole matching fog experience and i gotta disagree
i tried to find matching plug and play bulbs, i used sylvania silverstar ultras (30 something bucks), LED fogs, and even bought a set of PIAA bulbs for $60 freakin bucks. It was all a waste of money.
Halogen is not and never will be a good color match for the OEM HID
In the end i was happiest with a $35 DDM tuning HID kit, made a world of difference and looked like the lows (@4500k)
I actually have Lumincs H11 Ultra White bulbs right now, and they suck in terms of light output...it's just like stock...except a little bit whiter. But I can't tell that my fog lights are on with either stock bulbs or Lumincs bulbs. HID is the only way to go to get a noticeable difference.
Anybody have a link to the DDM Tuning $35 HID fog light kit? Does this kit include relays?
Did you just do the 35w, H11, 4500k kit (I guess you don't need dual in/out right?)? I see it here: http://www.ddmtuning.com/Products/DD...ast-35W-or-55W
I have some cars other than my toyota corolla, one is probably an acura i am almost positive : )
and yeah my best advice is to pull the trigger on the 35W DDM slim kit that you linked to, exactly as you said, 35W H11 4500s, no extra adapters or harnesses will be needed
the price went up to 40.00 but i still feel they are a great value, i can post a pic of my cars fogs if you guys are still unsure though.
the 55W can be a bit overpowering, my friend bought a set and they are brighter and more distracting than his lows and at 55W it has the potential to damage the wiring and housing.
What alot of people i know have done is to buy the DDM slim kit at 6K and then buy an extra set of d2s HID bulbs from DDM (or the appropriate hid bulbs for the 4g TL) and swap out the bulbs from their lows too, this way you have a perfect match top and bottom. That all being said, i felt that the 4500k kit matched the stock color quite well and the 200 lumen difference is barely noticeable unless you stare into the HIDs for a while, but then you will be blind anyway so who cares
not sure about the 4G tl actually, i used search but it didnt really turn up any results other than a few random threads. i am pretty sure you will not need a relay for the fogs, only the drls/highbeams if you swap em. I have used the DDM slims with 2 other new cars and had no issues with plug and play, i think you guys will be fine
I read that DDM Tuning were stopping sales of all HID kits. So even if they offer lifetime warranty, they might run out of stock and not honor the warranty.
I just ordered HIDextra.com Slim Ballast H11 6000K kit with a wiring harness for $91 shipped. The description did not mention if this was a 35W or 55W kit. Anybody know the wattage of the kit? The Part of the ballast says 35DC-C4 and the sticker on the ballast might say Power 35W (I think). It's hard to tell in the picture as the print is very tiny.
He is correct. DDMtuning stated on bimmerforums that they are winding down production on the slim kits and that they will be doing a last run or something to that effect starting march 1st. After that they will stop selling DDM branded kits. That being said, they also said that they would keep enough reserve slim kits at hand to satisfy all warranty claims for the forseeable future.
go to the cartalk section and search for ddmtuning, a recent thread has a link a to where on bimmerforums this is discussed
So how much hp/tq gain do you get from this HiD kit?
How much faster will my car drive with these hanging on my front bumper?
InFaMouSLink
10-27-2015 06:51 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
