Headlight Washers in US TL?
I live in MN and would very much appreciate having headlight washers this time of year, which I just learned are available on Canuck TL's. IS there a way to special order headlight washers in US TL's? Or, can they be added aftermarket? Thanks!
Cheap, Easy or possible to just hook up = no
Your best bet for what you're looking for is to actually drive into Canada, find an Acura place and order the whole assembly after having a sales tech associate pull up the diagram for it. Chances are, if you don't have to buy the Candadian Bumper for it (which means cutting into your bumper), you'll have to buy the squirter assemblies, a new reservior tank (as it probably has an increased number of lines, maybe 2), a new wiring harness to run the washer units to the fuse box, and then you'll have to get a canadian TL technical manual to learn how to wire it all up correctly.
Sounds like you should've bought your TL in Canada, haha.
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
