Had a question on lights.
2013 Acura TL the side marker lights in the front of the car up by the hid light is that a 168/194? amber? (Can I switch it with an led without getting a code.) Question 2 the bottom directionals are they 3457s or 3057s I know there amber I want to switch them to white leds I know that might throw off a code so I will need resisters to get rid of the warning codes what kind should I get?
Not sure the Sylvania bulb guide does not note one for their SYLVANIA 168 ZEVO LED Mini Bulb, guessing I would just try it and see it is does or does not. I am going to guess the small voltage different probably wont cause a problem. Honestly I would do the plug and pray method & if it fails, test the bulbs resistance with a multimeter.
juniorbean
08-05-2002 10:25 AM
synth19
10-23-2001 09:37 PM
