Gas type
Latent car nut
Received 2,008 Likes
Some folks have been reported to run Regular or Mid-Grade. The long and short of it is, running a lower grade fuel will negatively impact performance and fuel economy.
Ah, the ol premium vs. regular discussion. Well, I guess I can't complain. I recently posted a lightweight pulley thread which has been discussed ad nauseum.
There s a fair bit of argument on the subject, but bottom line is, the engine has a pretty high compression ratio, which warrants the use of premium fuel. If you consider the science behind it, premium has more octane which prevents pre-mature ignition (spark knock) of the fuel/air mixture before it's supposed to ignite. Theoretically, if regular is used, it will result in more spark knock which can result in engine damage if done long term and reduced economy and engine output in the short term. Some have reported no problems with regular, though it would be difficult to assure there's no problem unless you were meticulously monitoring fuel economy, spark knock and engine power. Like Justn said, the ECU will pull timing to help avoid knock but this will reduce engine efficiency, usually erasing any price savings from the lower cost of regular.
I'd recommend using what the manufacturer indicates. But putting regular in will not cause the engine to blow up.
At least not in the short term.
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
Latent car nut
Pics of the long term results of spark knock. It's enough to scare me into using premium:
Spark Plug
![](https://4.bp.blogspot.com/-GVJPk3PVxzk/T3oZDhh6nHI/AAAAAAAAADM/RZlsTqw0xC4/s1600/bad+spark+plug+pre-ignition.jpg)
Piston Head
![](https://i0.wp.com/www.onpointdyno.com/blog/wp-content/uploads/2015/01/detonationpiston.jpg)
Cylinder head
![](http://www.grumpysperformance.com/headpics003.jpg)
Valves
Spark Plug
Piston Head
Cylinder head
Valves
Just to be clear, high(er) octane fuel will not prevent premature ignition of fuel, this is called "pre-ignition", a condition which will destroy an engine in only a few rotations. What higher grade fuels are designed to do is to reduce or eliminate "detonation" (aka. "spark knock", "knocking", and/or "pinging"). Detonation is the spontaneous combustion of small pockets of "end-gas" on the far side of the combustion chamber well after (in relative terms) the spark event.
horseshoez (12-18-2017)
Latent car nut
Spark Plug
Piston Head
Cylinder head
Valves
![](http://forums.iboats.com/filedata/fetch?id=7134180&d=1278302578)
Spark Plug
Piston Head
Cylinder head
Valves
Latent car nut
The flip side is light detonation is actually considered beneficial and highly efficient by many engine designers. The best place for spark timing to be is set relative to the grade of fuel currently in use, the current weather conditions, and the current engine RPM/load, is right at "incipient detonation"; the point where a fraction of a degree of additional spark advance will cause detonation to begin, but a fraction of a degree less will result on slightly less power. The beauty of modern engines is they constantly monitor detonation and keep things right at that knife edge.
Thank you for the insight. Learn something new every day ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
I'll stick with premium.
Also OP, keep in mind the additional cost of premium is usually around $.25 a gallon. Assuming 15K miles per year @ 24mpg, this would equal 625 gallons or around $150 per year. I'd be happy to save $150 a year but I think it's a bit like oil changes. I'm willing to spend the extra $$$ on synthetic and more frequent oil change intervals (literally one more per year) to prevent possible engine damage. That results in a cost of around $80 or so per year in oil (additional change and increased cost of synthetic). Of course, to eat my own words, I had my original engine crap out from bad oil rings at 130K miles so maybe it makes no difference
Latent car nut
Of course what was once a $40,000 car is now a $5,000 car. Just the same, if you want the size and space of a TL (or other Acura) but don't want to pay for Premium fuel, buy a Honda.
The following 4 users liked this post by horseshoez:
horseshoez (12-20-2017)
Keep in mind the ratings at the pump are the minimum octane the fuel contains.
The TL calls for 91. In most sea level areas Premium is 93. Regular is 87. Mid-grade is a mix of the two, so 90 minimum. A worst-case scenario (if both the regular and premium at your gas station contain only the minimum octane) is the mid grade you buy contains roughly 1% lower octane than recommended (not required) by Acura.
If you believe a motor made to be sold to the non-racing masses is going to be engineered so tightly that this could possibly have any effect then you're exactly the type of person for whom Premium was invented.
There is no law against flushing money down toilet and if it makes you feel good then it may be worth the extra several hundred dollars a year using premium will cost.
In 30 years I've never put premium in any vehicle I've owned and never had any issues. And that includes an '88 Kawasaki ZX10, which at the time was the fastest production vehicle ever made. At 997cc that motor actually had to work to deliver that performance. Owned it for 15 years, ran it only on regular. Maybe above 130mph there may have been some performance loss but I never went there.
Latent car nut
@Bat-1, keep in mind you cannot prove a positive with a negative.
No point to this post, but I purchased ethanol free 88 Octane one time and never felt a difference. Maybe the lower octane cancelled out the supposed increased power with having no EtO. That's probably thinking too much.
CTSV,TL, Audi Q7 & A5SB
It amazes me that this same topic comes up all the time, and it's not just on AZ. This topic constantly pops up on the Lexus forums, Audi forums, BMW etc...
In my over 30 years of driving, I know people who have never had an issue using regular all the time regardless of the octane requirement. And I also know others that have had issues from the long term effects of using a lower octane than what is required.
IMO everyone should use the gas they want to for their vehicles. If you lease your vehicle it probably won't matter since you will turn it in long before the long term affects of using the wrong octane could have an effect on your vehicle. But if you own your vehicle, and plan to keep it a long time using regular when premium is required might catch up with you one day.. Or maybe it won't..
I'm not taking that chance, for me it's simple, if my vehicle requires premium I use premium regardless if it's a lease or if I own it. IMO the cost difference between regular and premium grade is cheap insurance to keep things running correctly..
a35tl (12-22-2017)
JT4 (12-21-2017)
Shell V-Power for the past 12 years. The only 91 octane premium with no ethanol in my area. Started using it on cars that don't require premium to keep the engine clean, get better mpg and the better throttle response.
![Canada](https://acurazine.com/forums/images/smilies/canada.gif)
Latent car nut
Ummm, no, Shell V-Power will not keep your engine any cleaner and, unless the engine is designed for Premium fuel, you will get worse fuel economy.
Higher octane fuel won't leave less residue after combustion in the cylinders?
And yes on my 2 previous cars that didnt require premium fuel (2001 Altima and 2006 Accord) had better mpg with 91 octane. More octane better explosion so you need less fuel to acheive same performance.
Latent car nut
Primer: The higher the octane the cooler and slower the burn (fuel in engines does NOT explode, it burns as in a whoosh across the combustion chamber), and a cooler and slower burn yields less power and more deposits. In addition, due to the extra additives in premium fuel, there is slightly less heat (power) potential per unit of fuel compared to regular.
Untrue, in fact, in lower compression engines not designed to run with premium will be less clean when running a fuel with higher octane than recommended due to the cooler burn and yield a lower fuel economy. Exactly who is telling you otherwise?
![Red face](https://acurazine.com/forums/images/icons/icon11.gif)
My previous odometers with a full tank of gas.
Latent car nut
Correct, unless you have a high compression engine which leverages the anti-detonation properties of premium fuel by increasing the pressure/temperature of the intake charge (a product of the higher compression ratio) prior to the spark event, your fuel economy will be slightly lower. That said, the difference is typically small enough unless you put your engine on a stand and connected to a dynamometer and use it to measure the Brake Specific Fuel Consumption (BFSC) which measures the specific fuel consumption for producing one horse power for one hour, you will not be able to detect the difference.
Personally, I just stick to what's recommended. I use regular in the Pilot and premium in the TL. Funny thing is, they have nearly identical engines. Both are 3.5L's except the Pilot has that awful variable cylinder management (which I hate) and has a 10.5:1 compression ration as opposed to the TL's 11.2:1 which likely explains the difference in octane recommendation.
SkN012 (12-22-2017)
Thanks for the info. This community is knowledge as always. I guess the bottom line is to stick to manufacturers recommandations. Yet again, the oder day I had to gas up but only had a Petro-Canada nearby. Tried the 94 octane with 10% ethanol and felt a better response. Another placebo effet?
Made the mistake of putting 87 in my Integra 1 time.. Lesson learn never again. Ain't cool having sputtering issues when it's -17F in the middle of the Alaskan Highway. As for the TL I have a tune on it so 93 is what it will be running until I make most for E85. As for oil? lol ENEOS Sustina is all I use now 5w-30.. 0w20 on my Accord.
Regarding oil, you can theorize however you'd like - whether your Wal-mart lube job is sufficient or if the $80+ Amsoil ones are worth it. That's easily tested with Blackstone though.
https://www.blackstone-labs.com/
Of course marketing plays into some of the popularity of oils and gas but there's also a reason some are more expensive than others.
