FYI - Battery Replacement
Keeping TL until 2029
When I first got my TL, I was able to get a battery replacement for free under the 4 year warranty period and II have pushed my stock Acura battery for about 5 years (60000 km's) with mainly city driving. Luckily, the battery failed on my driveway and after looking at these forums I knew that a failed battery was inevitable....
a. I have Tech version so nothing worked. i.e. doors, gas and trunk release but interestingly, the alarm still blinked. I had to use the key to open the drivers side door.
b. It's pretty easy (it was my 2nd time changing a battery but the first time on my TL) and there are a bunch of DIY videos on the inter-web.
c. I unplugged the battery and replaced it with this one.
d. My concern was the size as the TL battery is 24F and the battery above was a 34F. The 34F battery includes a spacer to make the size match perfectly.
d. Once the car was restarted, it remembered all the primary settings. Driver 2 would need to be re-set.
e. Be prepared for the radio code, Once you reset the car, the Navigation Screen to ask you to enter it using our 1-6 preset buttons.
I have considered a battery tender to keep the settings but in the end, it wasn't that much of a big deal. The next then I need to do it test with volt meter if there is an issue with alternator......
KarKraze (06-08-2018)
Are you still able to put the "battery port" portion of the shroud on? When my battery went, I needed to get a replacement right away, and the only place open was Walmart. The battery I got there works beautifully, but I can put the battery cover back on.
Good to know; that MotoMaster Eliminator AGM is a great battery. I got one for my wife's Pilot some time ago, and it performs like a champ. If and when my Walmart battery goes, that's likely what I'll be buying.
I am still on the Original battery ( lucky, I guess ) and hook up a Battery Tender during Winter storage. Lately, I have been thinking of a replacement since they seem to go out suddenly, good info !!
It was sudden alright. I drove all the way to Stouffeville (Doors Open) and back for this event.
Richmond Hill Live Steamers
In the late afternoon, I tried to drive the car and the battery was dead. There was no warning at all....
The Acura batteries are stupid. I have an exact thread about this issue. Two bought-new Acuras with 4 crappy dead OEM batteries within 5 years. The last (and current) ones I bought are from Costco for $90.
What's even more stupid is their warranty policy. If a battery is replaced under warranty, there is NO warranty on the battery after the factory warranty runs out. So it's replaced on the last day of the 4 year factory warranty and it dies the next day, you are out of luck.
Basically their 100-month warranty is only valid when you buy your battery.
Yep my battery went bad after 28 months - so I went with the monster Odyssey Extreme 34R-PC1500T with a spacer. Deep cycle extra protection for the car cam. 1500/1250 850CCA
Damn and I thought i was the only one. I had to almost weekly charge my OEM battery. Went with Optima Yellowtop due to extra electrical draw from my dash cam. Now I charge the battery every... 6-7 months due to the camera and me not driving often.
echodigital (06-19-2018)
I have not connected a dash cam on my car. Is there a way to connect the CAM without drawing power unless you are driving it? I don't think I would want the 'feature' to record things when I am not there i.e. getting bumped in a parking lot.
HondaFan81
08-13-2011 09:45 PM
pimpin-tl
08-11-2006 02:16 PM
