Fuel System Cleaner
Old 06-12-2016, 08:54 PM
lltfly's Avatar
Fuel System Cleaner
Hi,
I am thinking to pour some fuel system cleaner into gas tank to clean up or prevent buildup and some deposits.
Did some search. most of cleaners just are detergent. not working well on cleaning. But it is ok for prevention.
However, accidentally, saw a post that too strong cleaner like Techron is going to dissolve the buildup from wall of tank and maybe clog the fuel filter.
And dissolved buildup may clog the exhaust catalyst.
What kind of cleaner do you use? Any recommendation or ideas?
Old 06-12-2016, 09:40 PM
Reorge's Avatar
As far as I know detergent and cleaner are the same thing. I don't know of anyone having issues with buildup in the tank nor do I think it would be an issue.
Keeping the back side of the intake valves as clean as possible is the reason I use Chevron Techron. It also cleans the injectors.
Old 06-12-2016, 10:56 PM
Anicra's Avatar
Most of the top tier gas should keep the system pretty clean.
When I use a cleaner, I have the gallon jug of Lucas Upper Cylinder Lubrication & Injector Cleaner.
https://www.amazon.com/Lucas-10013-F.../dp/B000FW7V50
then I refill smaller jug for using on the car and refill as needed.
https://www.amazon.com/Lucas-10003-C.../dp/B000ARPVOI
Since I have some really crappy in the middle no where fuel ups. (I stay away from Cenex like a plague)
I think I do once in spring and fall.
Though there are many gas stations that look nice however the gas storage tanks are not exactly perfect.
Side-note: Top tier gas is an example where EPA legislation actually lower the amount of detergents and cleaners in the premium gas. Since a large number of fuel companies already were putting in 2 to 5 times the required Top Tier detergent levels of today. Some companies just lowered the amounts detergents since requirements were far less.
Old 06-12-2016, 11:15 PM
Anicra's Avatar
Other cleaners I have used in the past...
Red Line Complete SI-1 Fuel System Cleaner, Chevron Techron Concentrate Plus Fuel System Cleaner, and/or Royal Purple Max-Clean Fuel System Cleaner and Stabilizer
Old 06-13-2016, 07:19 AM
JT4
CTSV,TL, Audi Q7 & A5SB
JT4's Avatar
Same here I use Techron in my vehicles too..
Old 06-13-2016, 10:00 PM
csmeance's Avatar
Received 2,016 Likes on 1,435 Posts
Redline in the fuel and seafoam through the intake
Old 06-14-2016, 07:50 AM
uptownarty's Avatar
The one product Ive used and not too many people care to know about is called 44K by BGE. I drop a full can in on a quarter tank before fill up and watch the sparks fly. The stuff is been around for the longest time. In fact I once had a clown at Jiffy Lube tell me I had to drop a few hundred to do a fuel system cleaning. I told him let me think about it for 24 hours.....I went bought a can and came back the very next day....Guess what he saw the next day!! Look it up, BGE 44k, its a good secret to keep to yourself.....
The following 2 users liked this post by uptownarty:
954Rocks (11-01-2016), Anicra (06-14-2016)
Old 06-14-2016, 03:22 PM
Anicra's Avatar
Rofl I forgot about BG 44k I have a couple on the shelf in the garage. Good call Uptown
Old 06-15-2016, 10:16 AM
CTNYC's Avatar
I second Lucas fuel injection cleaner... My TL's power and acceleration was dramatically smoother after using their product (although it was the first time it was used @~105k miles or so, so I'm sure there was a lot of buildup in the fuel injectors). Also I bought the car second hand @~85k miles - I to only use Costco or Shell premium/Vpower, but no clue what the previous owner used for the first 85k miles. I usually just put in 3 oz into my tank every few tanks and my car has been running smoothly.
Old 06-15-2016, 09:05 PM
lltfly's Avatar
Seems like Lucas upper cylinder lubrication and fuel injector cleaner are good to go?
Old 06-16-2016, 12:32 PM
CTNYC's Avatar
Definitely try it out - it's a few bucks for a small bottle and they are a fairly large company that many people swear by (google search Lucas Oil upper cylinder lucubration and fuel injector cleaner review or look at the reviews on amazon, advance auto, etc... All I'm saying is that you can't fake that many reviews
Old 06-16-2016, 01:45 PM
Reorge's Avatar
"... sparks fly."?
What did the clown at Jiffy Lube see?
Old 06-16-2016, 01:59 PM
UlsterBoy13's Avatar
i use seafoam in the gas tank a couple of times a year, and once a year or so depending on miles, put a bottle of Auto-RX in the crank case for 3k miles.
Old 06-17-2016, 12:24 PM
boss2k's Avatar
Hows this
https://www.amazon.com/Lucas-10020-F...TJ2G45GDS1WNF8
does it work for unleaded fuel like our cars, somwhere i read the product is for leaded fuel only
Old 06-17-2016, 01:27 PM
boss2k's Avatar
This one looks better
https://www.amazon.com/Sea-Foam-SF-1.../dp/B0002JN2EU
Old 06-17-2016, 04:32 PM
lltfly's Avatar
Originally Posted by boss2k
Hows this
Most of gas stations are unleaded. It is only working on leaded? I just added a bottle last night~~~
Old 06-17-2016, 04:45 PM
lltfly's Avatar
Hows this
" Lucas Fuel Treatment should definitely be used in vehicles that require leaded fuel because it actually replaces the benefits of lead in gasoline without causing harmful emissions. Use it to pass smog tests. Finally, it totally neutralizes the harmful effects of low sulfur diesel fuel."
I saw this description on Amazon, Lucas upper cylinder lubricant. Is it harmful I have already put into my gas tank~~~~~
Old 06-17-2016, 09:05 PM
Anicra's Avatar
Ya it for Unleaded vehicles.
When I was a kid - regular fuel was the leaded version of gas. Now I swear you say that now and people think you are talking about 87 octane unleaded gas.
When it comes to injector cleaner - you are going to have a diverse answers in the same manner, if you would have asked best fuel...
Old 06-18-2016, 04:50 PM
CTNYC's Avatar
Lucas works with both unleaded gas and diesel engines - I use it all the time with my 4G TL and used it previously on various Acuras, Buicks, BMWs, Mitsubishis, Mercedes, etc and worked well
Old 06-20-2016, 12:59 PM
boss2k's Avatar
How seafoam cleaner?
gavriil
10-07-2021 08:38 AM
00TL-P3.2
02-11-2019 11:23 AM
TSX69
3G RLX Audio, Bluetooth, Electronics & Navigation
94
09-17-2018 07:45 PM
Aquaholic
1/2G MDX (2001-2013)
09-04-2016 04:46 PM
Rob_TL
20
05-25-2016 01:43 AM
Quick Reply: Fuel System Cleaner
