Engine weird knock noise?
First, check the oil level, then use a stethoscope to locate the source of the noise.
Timing belt tensioner
My knocking noise on 2013 TL SH-AWD was the timing belt tensioner. Replaced, all good now.
QUOTE=volcomstonebus;16744873]2010 acura tl sh-awd
i know i need a valve adjustment but i keep hearing this “knock” noise? Any suggestions?[/QUOTE]
Could be a few things if the tensioner and belt were replaced. If you are doing a valve adjustment, check the cam lobes at that time as on the j37 they tend to deteriorate prematurely.
habeebster123
01-19-2022 03:15 PM
