Engine Oil Drain Plug
Love Guru
![Cool](https://acurazine.com/forums/images/icons/icon6.gif)
Anyone replaced their Engine oil drain plug? While doing an oil change over the weekend, I noticed that the drain plug that I have in my car needs to be replaced. Since I was doing the service myself, on a Sunday, the Acura dealership was closed, and Pepboys and Advance Auto didnt have the replacement one for my car. So at the end, I installed the older, damaged one back. I think next oil change will definitely require me to replace the plug. Now my question to the folks that did replace the drain plug, where did you buy it from? Dealership? Ebay? Amazon? Local Auto store? I was looking around and came across some on Ebay that had straighter edges. Something similar to these.
M14 x 1 5 Red Engine Oil Pan Drain Plug Bolt Honda Acura Mazda Mitsubishi Suzuki | eBay
and:
Red Anodized Magnetic Engine Oil Pan Drain Plug Bolt w Crush Washer M14X1 5 | eBay
Anyone tried them? I dont really care if the drain plug is red, blue or rainbow color. As long as its the right size and works like it is supposed to. I couldnt confirm the size that will work with my car. Link 1 says that M14 x 1.5 is the size, but the Link 2 says that it is not.
and:
![what](https://acurazine.com/forums/images/smilies/what.gif)
Love Guru
Love Guru
Love Guru
I can't help with the correct size but I bought a replacement at a local auto store (Advance Auto Parts I believe). The only real difference between the one I bought and the OEM version is the washer/gasket is plastic on the former and metal on the latter. If you didnt' feel comfortable with that I'm sure it could easily be resolved with a quick trip to Home Depot.
^^^I've never really understood that...at least when it comes to the metal ones. It's not like they wear down, especially that quick!
I did go back to the metal one I had when the time came to change my oil after I used the non-OEM version. I didn't feel comfortable using the plastic one a second time.
ucf_bronco (09-17-2014)
^they're called "Crush" washers.
once you tighten it down, they crush.
one time use.
except, most people reuse them.
Including me.
I did notice in my mom's '12 Kia sportage that it was leaking from the drain bolt. I suspect the "crush" washer didnt clamp or seal all the way and had bought 10 crush washers from the dealership and on the next oil change will swap to a new one.
one time use.
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
Including me.
some idiot at the dealer not only damaged my drain plug but also the oil pan in the process by forcing it in. they had to replace the entire thing. didnt cost me a cent, although my entire saturday morning was wasted.
Love Guru
I used the white Nylon crush washers in one of my previous cars. I think they were alright too for three reasons. One, they are much softer than the aluminum ones, so they will create a better seal, two, since it is nylon, they wont get rusted over time and wont require too much torque to open the drain plug. And three, since they are made out of nylon, I will need to replace them with ever oil change. So I will have no reason, or excuse, to reuse them.
justnspace (09-18-2014)
The problem is that they use an impact gun to screw in the plug. It's a good thing that they fessed up and repaired the damage.
I used the white Nylon crush washers in one of my previous cars. I think they were alright too for three reasons. One, they are much softer than the aluminum ones, so they will create a better seal, two, since it is nylon, they wont get rusted over time and wont require too much torque to open the drain plug. And three, since they are made out of nylon, I will need to replace them with ever oil change. So I will have no reason, or excuse, to reuse them. ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Love Guru
The only time I did use them, I bought them from an auto parts store, it was Advanced Autos I think. I think I paid 1 or 2 bucks for a pack of 6 or something like that. But they were super cheap and it did not hurt me a bit when I had to throw the used one away. haha.
Perhaps this will do. 100 of them for less than 3 bucks. Assuming that the drain plug is M4 size.
ucf_bronco (09-19-2014)
