Driver Side Mirror Housing Replacement / Gap Between Mirror Edge and Housing
Old 01-31-2011, 11:35 PM
8th Gear
TLGuyNJ's Avatar
Hello.
Does anyone know where I can find information on how to remove / replace only the outer housing on the left / driver side mirror?
I don't see how and why I would need to remove the entire mirror from the door panel etc...
Also,
Is it normal to have a gap between the inside glass portion edge and the housing? I want to make sure mine is normal compared to others.
Any help on the housing replacement would be appreciated!
Thanks!
Old 01-31-2011, 11:37 PM
8th Gear
TLGuyNJ's Avatar
Originally Posted by TLGuyNJ
Hello.
Also,
Thanks!
This by the way is for a 2010 Acura TL SH-AWD w/Tech 5AT.
Old 02-01-2011, 06:38 AM
The Sicilian
jspagna1's Avatar
Here is a diagram of the mirror. Maybe someone can provide more detail,but I still think your going to have to take it off the car in order to take it apart.
http://oemacuraparts.com/partlocator...layCatalogid=0
Old 02-01-2011, 10:00 AM
8th Gear
TLGuyNJ's Avatar
Thanks.
Yea I got a similar one from the Acura eStore. Thats insane if you have to remove the door panel. There has to be an easier way. Its only the shell / housing that I need to replace. Not the guts inside the mirror.
Do you know where I can get the 2010 TL Service Manual?
Old 02-01-2011, 10:09 AM
normallywho's Avatar
I guess it depends on how much of a gap you're talking about. There has to be some gap because the mirror needs to move around in there. The way I have my mirrors aligned there's actually a rather significant gap because the mirrors face pretty for out to either side.
TLGuyNJ (10-11-2011)
Old 02-01-2011, 05:12 PM
8th Gear
TLGuyNJ's Avatar
Would you mind putting up a picture of yours?
Thanks!
02-25-2020 09:57 AM
csmeance
09-10-2018 09:15 AM
nanos
11-12-2015 08:41 PM
Ny1718
09-11-2015 09:21 AM
08 NBP TL
09-08-2015 08:49 PM
Quick Reply: Driver Side Mirror Housing Replacement / Gap Between Mirror Edge and Housing
