DIY Video Tutorials - Headlight Armor Lighting Protection Film - Acura TL
While current composite headlights resist breakage significantly better than headlights in the past they are highly susceptible to pitting and eventual hazing. Adding a tough layer of protection will greatly increase the life of the headlight. Once the sand blasting starts and the factory hard coating starts to wear away the degradation starts.
Want to protect your lights from the ravages of the road?
Afraid you can't DIY?
Check out the videos!
DIY Install Video Tutorial - Acura TL - Headlight Armor Clear Headlight Protection Film Kit
DIY Install Video Tutorial - Acura TL - Headlight Armor Clear Signal Light Protection Film Kit
DIY Install Video Tutorial - Acura TL - Headlight Armor Clear Fog Light Protection Film Kit
Hope you find the tutorials helpful. Let us know if you have any questions on the application shown.
If you have product questions please see our vendor thread here
The following 2 users liked this post by HeadlightArmor:
echodigital (10-11-2018),
justnspace (10-10-2018)
HeadlightArmor (10-10-2018)
Pretty cool. Any product you recommend to recondition before applying your protective film? I've been thinking of reconditioning since the edges of my headlights are starting to haze up a bit.
If your headlights are in need of a full restoration first this kit from Sylvania comes recommended.
https://www.sylvania-automotive.com/...es/hrk_kit.jsp
If you just have light pitting / hazing the adhesive on the materials we use may do a good enough job.
See how it works and see how to test yours before you go that route:
Hope that helps.
Hope that helps.
HeadlightArmor
3G MDX (2014-2020)
10-11-2018 07:54 AM
