Day time running lights
6th Gear
I'm looking to upgrade my D.R.L to LED and was wondering if I have to use a relay or something or is just plug and go? T.I.A
You apparently you can use there set up 9005 69-SMD LED Daytime Running Lights For Acura Honda Lexus Subaru, etc and I believe it is decoder R2
Not sure how this one is doing it , my friend put these and it worked for both. I did the same and I have DRL and Strong Highbeams. I am sure it will shortened the life, at one point I was debeating about pulling the DRL fuse under the hood. All I had to do is just plug it in. Actually my mechanic friend did it, since I had a cast on my hand.
