Catch Can install
Catch Can install
Hey guys
how should I route the two hoses to my catch can?
I see I have a hose from boot going to rear head valve cover,
and a hose going from front valve cover to intake plenum.
which wat is correct way?
thanks
thanks
Isn't a catch can unnecessary on these port-injected motors?
as long as a engine has a PCV which diverts fume's back in intake it would be good to run one. keep those valve extra clean. this has been covered many many times.
If you're convinced it'll work, go nuts!
A catch can isn't a great idea for a NA, port injected street car.
If they were a good idea...then you'd see them on cars from the factory. Right?
How many 200K or 300K mile J series are out in the world? A lot. How many of them do you think have catch cans? Probably 1 or 2?
I'd skip this idea.
You're going to introduce a lot of moisture and contamination into the oil.
Where do you plan to route the catch can outlet to? If you're routing it to atmosphere, then get ready for a very smelly experience inside the car. As well as oil film coating the surrounding areas near your catch can.
If you're routing back to the intake...then...the car already came like that. So...what's the point?
Virtually all cars come with PCV systems. They're designed to work well in their closed loop OE design.
You have a port injected car. Fuel sprays onto your intake valves. Why do you need to protect the valves from oil vapor? Are your valves dirty? If so...its more likely due to the fuel you use.
Chances are your valves are already "extra clean".
I'd skip this idea.
To answer your question, however...
both valve cover breather hoses get plumbed to the INLET of the catch can.
If you want to vent your can to atmosphere like its a race car, then you can cap off the intake manifold suction port with a vacuum plug. You will quickly find out how bad of an idea this is, however.
If you want to vent your can back to the intake plenum, then you just route the OUTLET of the catch can to the manifold port.
Think of creative ways to heat the can. Does it come with coolant routing to keep the can hot? Or?? Just YOLO?
But...I still encourage you to ask yourself why the car didn't come with a catch can. Think about it before you do this.
Jim2301 (08-12-2022)
I'd skip this idea.
I'd skip this idea.
BROlando (08-06-2022)
Sorry to dig up an old thread, but would someone be able to explain why catch cans aren't necessary on port injected engines? I would have figured that with the j37's oil burning problems that installing a catch can would be a common mod for people to do on these cars.
But you may be asking "why not install a catch can on a car that's already burning oil via worn piston rings?"
Valid question, since the blowby would cause more oil mist to be produced and enter the intake tract. Adding a catch can would catch some of that mist before it made it to the intake tract.
Problem with catch cans is proper venting and moisture build up.
Proper venting can be done with some cunning.
Moisture, however, is harder to avoid. Moisture will build up inside the can and then will make its way into your oil. Most catch can systems on the market aren't heated and don't return the catch to the crank case.
Introducing moisture into your oil will make the car burn more oil. And will shorten the lifespan of your oil. Your poor oil has to deal with fuel dilution from the worn rings already. With a catch can, it also has to deal with nasty, dirty assed, water being introduced.
I'd rather just forego the catch can and let the oil mist enter the intake manifold and let the fuel wash the intake valves off. Port injected cars have that going on.
The reason that manufacturers use catch cans (actually they're AOS's) on direct injected cars is to catch the oil mist in the crankcase ventilation before it makes its way to the intake ports. Reason?
The crankcase pressure is high and the fuel dilution is also high, since you're directly injecting fuel at high pressure. So more oil mist is produced.
If you then suck that oil mist into the intake manifold and lay it all over the intake valves...you'll cake the valves in oil and carbon very fast. There is no fuel spraying on the valves to wash them. So the carbon will just build and build.
That's why you see AOS's on direct injected cars. OEM AOS's are heated and will return condensed oil back to the crank case via some sort of valved drain. So they're also more complex than a can you buy on eBay.
bryan916 (07-11-2024)
The catch can does nothing to prevent or help oil burning.
thewrangler99
09-09-2022 12:46 AM
