Brake Replacement options for 2012 Acura TL SH-AWD
Good Evening all,
I have always used Brembo blank rotors for my previous cars, I see brembo does not make rotors for this car, anyone have goodluck with other aftermarket rotors or should I just spend the money on OEM?
Tommy
Tommy
In before Adam's Rotors comes up....I believe they're a sponsor on the forum so there's quite a few people (the vendor included) that drops in on these threads. They're available here:
2009+ ACURA TL MODELS
Alternatively:
https://www.tirerack.com/brakes/resu...nology+Package
I've used Centric Cryo treated on my S2000 with good luck, and I don't think StopTech is going to be a bad option either.
Alternatively:
The XLR8 package looks good. Info in the performance section of the 4G sub forum. I ordered and received mine recently (the blank stoptech rotors with the ceramic pads). They look pretty good quality stuff. The front each rotor weights a little less than 20lb and the rear a little less than 10lb. Haven't installed them yet... life too fast lately, no time! Hopefully before winter comes. Believe it or not, the OEM still going strong, have another 40% life after nearly 6 years on the road.
BTW, change the brake hose/lines too, get stainless steel. My plan is to first change these hoses to the stuff I got from XLR8 and then the weekend after change the disks pads. This way I'll make sure nothing leaks after a week and second I am curious to see if the staleness steel lines alone make any difference. Also need more time to clean re-paint the calipers. Big job!
Just some random thoughts.
ExcelerateRep (07-27-2015)
Great website to visit if interested in installing new rotors -
Why Deep Cryogenics? - Frozen Rotors
Our proprietary 60 hour cryogenic process permanently and dramatically improves the usage life and stability of brake rotors to create a distinct advantage in tensile strength, abrasive wear resistance and rotor longevity. By using the cryogenic process to inhibit internal oxidation and increase thermal fatigue resistance, a cryogenically treated rotor can last up to three times as long as untreated rotors.
Former Sponsor
As Tonyware mentioned, definitely check out our XLR8 Brake Packages! They are designed to perform well and last, without costing an arm and a leg!
Acurazine Brake Packages ACURA - Excelerate - HOA - Japanese Performance Specialist
Nitin
09-30-2015 08:22 PM
asahrts
09-04-2015 05:55 PM
