Autoblog reviews the 2012 TL on 3-9-111
A nice array of large images of a 2012 Mayan Bronze TL with the umber interior is offered. The reviewer discusses the known exterior changes as well as the items listed below.
"...Designers have swapped out the dimpled chrome accents of the dash and door panels for a fish-scale material that looks more at home in a vehicle of this caliber, and buttons along the stereo are now color-matched to the rest of the controls on the dash. "
"...That new face doesn't simply look better. It also helps serve up a 5.4-percent reduction in drag thanks to changes in the grille and lower fascia. Additionally, airflow through the radiator has been optimized and new underbody cladding helps reduce turbulence from below to make the sedan as slippery as possible. Engineers also bolted on a new intake system that focuses on bringing in fresh, cool air from outside of the engine bay. Cooler temperatures mean denser air, allowing the ECU to slightly advance the engine timing to increase torque and efficiency. Additionally, the pistons in the 3.5-liter V6 now make use of a moly-dot coating to reduce friction. The piston skirts wear a matrix of lithium dots that work in concert with a new block boring process to keep mechanical drag to a minimum.
Those substantial alterations join new dual-fine-electrode spark plugs and low viscosity 0w-20 oil to make the 3.5-liter as fit for fuel economy duty as possible. All told, the engine is good for 20 mpg city and 29 mpg highway – up from 18 mpg city and 26 mpg highway in the last generation – all while delivering 280 horsepower and 254 lb-ft of torque.
"...For those who don't exactly find themselves braving glacial roads for a good number of days out of the year, we'd just as soon recommend saving some money and sticking with the front-wheel-drive TL with its new-found enthusiasm for fuel efficiency. Speaking of money, Acura has priced the 2012 TL starting at $35,605. If you absolutely must have the SH-AWD, be prepared to fork over $39,155.
It's worth noting that Acura kept the excellent six-speed manual transmission as an option for the TL, but it's only available in SH-AWD configuration with the Technology Package. As such, that vehicle will command a lofty price tag of $42,885. "
source: http://www.autoblog.com/2011/03/09/2...iew-road-test/
quanaman
01-09-2023 07:33 PM
joflewbyu2
08-18-2019 10:38 PM
ITSJESTER
17
12-06-2018 02:29 AM
