Is the Acura TL SH-AWD 3.7L V6 engine as refined as the 3.5L V6 Lexus IS350?
Old 12-06-2009, 04:34 PM
GrigioTL's Avatar
I had a Lexus IS 350 3.5 liter V6 DOHC (306 hp/277 lb-ft torque) before getting my TL SH-AWD Tech in September. I have noticed that the Acura TL SH-AWD 3.7 liter V6 SOHC (305 hp/273 lb-ft torque) does not feel nearly as refined and as powerful as my IS 350. Has anyone compared both vehicles? If so, what did you think?
Old 12-06-2009, 05:07 PM
2010 TL AWD 6MT: New King
docboy's Avatar
I had 09 IS 250 AWD for a few months before getting my 2010 TL 6spd, so I can only offer a perspective on the 250, not the 350.
The 250 of course had about 100 less hp than the 350, and obviously less powerful than either the TL or 350. The IS I recall was very quiet inside, and isolated me from the road and the car. I felt disconnected, as if I was watching the world go by me. Too serene for my taste.
The TL is also quiet; though not as quiet as the Lexus. But I feel more connected with the car and the road. The TL has a little more growl I can hear inside than the cabin than the IS at low end rpms.
I hated my IS with a passion. The only good thing about the IS was that its exterior is styled right and is a good looker. That's it. Even the navigation sucked; couldn't use the dam nav when the car was moving; what the hell is the point of the nav then??
The 6spd TL beats out the IS in terms of its transmission, comfort, interior design, performance, navigation, cargo space, and safety.
Old 12-06-2009, 05:21 PM
chaiwala's Avatar
Lexus prides itself in refinement so its definitely much more refined in terms of engine growl and acceleration. The best way I can explain it is that the IS350 has a muted acceleration to isolate its driver from the exterior noises while the TL has a throatier acceleration. But when it comes to Torque, the SHawd does wonders for the TL and is hands down the winner. Lexus may have refinement down to a sience but sacrifices performance by doing so. The TL in my opinion is just a tad bit less refined than the IS but is heads and shoulders above the IS in terms of performance.
Old 12-06-2009, 06:08 PM
GrigioTL's Avatar
I agree, the IS 350 is a very quiet ride compared to the TL SH-AWD. Sometimes I had to check if my engine was even running... I guess that's what Lexus means by the "the pursuit of perfection". Regarding perfomance, IMO the IS 350 feels much quicker than the TL SH-AWD. However, I agree the TL SH-AWD system is impressive. Remember, the IS 350 is rear wheel drive only. I found the IS 350 quicker for passing and merging into busy traffic. I recall the Lexus service advisor telling me that the IS 350 was a much quicker vehicle that GS 350 due to weight (303 hp/274 lb-ft torque). So maybe the TL-SH-AWD does not feel as fast because of weight?
Old 12-06-2009, 06:13 PM
GrigioTL's Avatar
I agree, the Lexus navigation really sucks. Apart from being unable to use it when the vehicle is in motion, the system is just not very user friendly. However, the new system in the 2010 RX 350 seems to have been improved.
Old 12-06-2009, 06:22 PM
05 slate grey e500 AMG sp
ssim3's Avatar
The SHAWD is a power leach there is a ton of driveline loss compared to rwd check Bob's Dyno on the RL site. The IS is also .2 liters smaller with equivalent power.
Old 12-06-2009, 07:01 PM
chaiwala's Avatar
Yes the IS350 is definitely faster than the GS350 since they both have the same engine and GS is heavier. The 3.7TL would definitely be slower in a straight line against the IS350. Heck I think the FWD 3.5L TL would be able to give the 3.7L a run for its money in a straight line test, rolling ofcourse. RWD IS or not, the TL has much better torque transfer and a blast to drive fast. The IS is too light for its power and acceleration leaves not to the imagination.
Old 12-06-2009, 07:15 PM
Colin's Avatar
Received 1,012 Likes on 567 Posts
It may be difficult to separate the engine from the chassis in this discussion. Motor mounts and transmission isolation will play a part in what you 'feel' in the drivers seat. But then again, I'm not sure if that is really your question. Are you speaking solely of the refinement of the engine, or the feel of the engine as installed in the car?
I know this might sound like I'm 'splitting hairs' here, but I also believe that the differences will be equally small. In all likelihood, many of these things are going to be design decisions, for example, if the Lexus is more 'refined' it's because it's their "thing". If the TL lets a little more engine sounds or vibration, it's because that's the cars 'sportier' mission in life. Does that make sense?
Old 12-06-2009, 07:32 PM
I have car ADD
BLACKURA_NY's Avatar
The IS350 is expected run a 0-60 in 5.6' .... and a 1/4 mile is about 14 flat
Acura does not list their performance times... but im pretty sure you can run low 6' times, and a 1/4 mile might be 14.3~ for a 5AT... the 6MT will be a little better
The IS350 is i believe around 3500-3600lbs... the SH-AWD TL (with Tech 5AT) is about 3975lbs... big difference
If the IS350 came in a 6spd, it would probably land in around 3400-3500lbs.. and would be dominating its class, or at least holding its own against a 335i
The J Series motor, is a fantastic engine IMO, the only thing the IS350 engine has, that i think is better, is DOHC....
Toyota/Lexus's VVT-i is not as good as V-TEC, because the V-TEC in The SH-AWD TL lifts both the intake and exhaust valves
Old 12-06-2009, 07:42 PM
PetesTL's Avatar
They're both very refined engines. Lexus is famous for noise isolation and a quiet ride, so their cars will definately ride more smoothly than Acura and have quieter interiors. As far as performance, the problem in the TL is the weight and 5-sp auto. The 5sp SH-AWD feels more like a car with a 270 hp V6 rather than one with 305 hp. (Although the Takeda ram intake helps a little in this dept.). I think the best experience in the TL is with the 6sp.
BTW, I think as a group, the Lexus V6 engines rank below only to Infiniti and BMW 6 cylinders as the best in the business. They are smooth, powerful, and get very good gas mileage. (It's surprising that the Lexus LS 460 V8 engine gets similar mpg as the TL's 3.7!).
Old 12-06-2009, 08:07 PM
ssim3's Avatar
Lexus has been using direct injection & 6-8 spd autos for yrs giving them a performance/economy advantage over Honda's products.
Old 12-06-2009, 09:07 PM
docboy's Avatar
FWIW, Car & Driver tested the 2010 TL AWD 6spd manual 0-60mph at 5.2 sec
Not too shabby I'm sure as other reviews test the 2010 TL 6MT, they will post their own performance figures. But I surmise 0-60 times will be around low 5'
Old 12-06-2009, 09:15 PM
jjsC5's Avatar
I"ve driven two TLs in the last week, and a GS350 twice. I drove both FWD and AWD TLs. The GS350 is significantly faster than they are.
Old 12-06-2009, 10:29 PM
winstrolvtec's Avatar
The 6MT SH TL is the only current TL model that is in line with the GS350 RWD and AWD. Until Acura gets the 6AT and an auto tranny that can be brake torqued/launched their auto models will remain slower than the competitions but at least they offer a manual.
Old 12-06-2009, 11:54 PM
docboy's Avatar
Have you driven the TL 6MT? I can attest that the auto and 6MT are 2 distinctively different cars.
The auto, more of a touring sports sedan; the 6MT, a spirited and aggressive, yet neutral handling, rock solid powerful driver's car. IMHO...
Old 12-07-2009, 07:12 AM
YetiTL's Avatar
Agreed! However, I'm always wondering what % of the piopulation use the braque torque ability when they go to work? Probably some smidgen fraction of the population. I'm not nitpicking on you, don't worry, but I can't stop myself from laughing when people talk about 0-60 & 1/4 mile times when talking about speed. While it's nice since it gives you an absolute measure, it's very rare you'll use that kind of launch ability when you'll drive normally, no?
Now, I can't make an on-topic statement as I've never driven the GS350 so I'll just shut up now.
Have a good day!
Old 12-07-2009, 07:33 AM
pimpin-tl's Avatar
The IS350 may seem better, but they have the engines have the issue with the knocking noise that is loud and Lexus says it's normal. The GS350 also has this issue.
Old 12-07-2009, 09:00 AM
Grandpa
George Knighton's Avatar
Received 2,609 Likes on 1,475 Posts
Bragging rights. That's the problem.
A significant minority of the potential purchasers look at the 0-60 and 1/4 times that are published in the motoring press, and will come away thinking that the automatic TL is slower than the competition.
The old bullet proof 5 speed automatic was the only logical choice for the TL at the time it went into production.
But they should speed the inclusion of the 6 speed automatic as soon as it is practical.
Old 12-07-2009, 12:47 PM
PetesTL's Avatar
I would say the 6-sp AT is most likely coming out in the 2011 model, along with new packaging options such as the Advance Package (as seen in the new ZDX).
Old 12-07-2009, 01:00 PM
Under construction
alexSU's Avatar
It may be quicker off the line but I think the Lexus IS350 will catch up and beat it at higher speeds.
Old 12-07-2009, 01:16 PM
GrigioTL's Avatar
The same publication, Car and Driver tested the IS 350 0-60 mph (automatic) at 5.1 sec. Lexus does not offer the IS 350 in a manual transmission. That may suggest that a manual IS 350 (if offered) may bring in a 0-60 mph time in the high 4s.
Old 12-07-2009, 01:34 PM
docboy's Avatar
It would be interesting to compare dynos/performance figures of the IS 350 and TL 6MT. It appears the 2010 TL's newly engineered manual transmission "off sets" some of the hindrances of its heavier weight/size/baggage accrued from the SH-AWD (compared to the auto version).
Old 12-07-2009, 01:37 PM
This 100% correct and it is something I didn't want to get into with my post but I am glad you brought it up since most people go off of what they feel (torque band and shorter gearing) and what a magazine or timeslip says it runs but that does not always translate to real world driving and scenarios and doesn't necessarily mean anything is faster. Most of the time 2 cars in comparison are too close to ever officially label one as faster.
I usually only pay attention to trap speeds because it's a fair indicator of what is going on in terms of hp to weight and I feel it's good for everyday driving comparison. With the 5AT as high as 99 mph and the 6MT as high as 101 mph that makes either SH TL in line with the best of it's similarly powered, sized, and weighing competition. Some might run better down a track or test better in a magazine but as you said no one is really driving a car like for their daily commute.
Old 12-07-2009, 03:14 PM
jjsC5's Avatar
No, have not driven a manual TL - no interest in one for reasons beyond my control. I've got another car that runs pretty good with a manual though
Old 12-07-2009, 03:48 PM
The Sicilian
jspagna1's Avatar
Engine wise, I think they are very compadible. They are both very dependable and I do wish the TL had a more performance oriented exhaust system. Even the G37 sounds aggressive compared to the TL. But I definitely like the road feel you get from the TL versus the Lexus.
Old 12-07-2009, 04:58 PM
Ramrodthrusterpuppy's Avatar
That's excellent....approaching 335i times with more weight and AWD...impressive. Now all they gotta do with the 4G Type-S is add about 45 more HP, shave some weight and get into the high 4s....I'll be the first in line!
Old 12-07-2009, 05:38 PM
YetiTL's Avatar
And sadly, some of those who drive like that tends to end up wrapped around trees and telephone poles. This tend to create a kind of natural equilibrium between the drivers from the irresponsible wannabe racers...
Did you know that when I got my 2003 Honda Civic, I was 25, was about to become a lawyer and had no insurance problem but it still cost me close to 2k$CDN per year to insure a 25K CDN car? All thanks to dumbasses who race their Civics and end up wrapped...around telephone poles and trees......
To be honest, I care about 0-60 and 1/4 mile to see the potential but I know too well the reality is different altogether. I don't spend my life bench racing so I don't care the 0-60 time of a Subaru WRX with a 6MT is 4,7-4,9 seconds...my car isn't a penile enlarger...
Old 12-07-2009, 06:15 PM
Kingmeow's Avatar
LOL! Maturity has its advantages!
Old 12-07-2009, 07:03 PM
YetiTL's Avatar
Yeap! Quite a few, I don't regret my twenties, the thirties are awesome so far: super shape, great job, nice cozy home, great car, much more money and more friends since I meet people all the time!
Old 12-07-2009, 07:28 PM
Eli
Eli's Avatar
If you took the Japanese luxury brands, and on one side you have comfort, and on the other sportiness. It's Lexus far into the comfort end of the scale, Infiniti on the opposite end, and Acura somewhere in the middle. The same probably applies to their regular brands, Toyota/Honda/Nissan. At least this is how the marketing wants us to see it.
Old 12-05-2012, 01:10 AM
STONEColdAcurazineLegendZ's Avatar
Acura TL's and Honda in General have beaten Lexus in Crash safety which the IS received one of the worst rateings compared to the ilx, and tl and etc.. toyota Camry even reiceived a better frontal crash test... soo overall the acura is the safest and will always be!!! all around acura's will be the best cars. every auto maker has there flaws... you can learn to love them or hate them... but your gonna have to deal with them btw The new Tl and tsx are great cars the Tl has a 280 hp j35 while the tsx has a 11-1 201 hp k24z7 engine these cars are new so there power band are very consistent.
Old 12-05-2012, 01:13 AM
http://www.iihs.org/ratings/ratingsbyseries.aspx?id=560
Poor Front crash rating...for the Lexus
http://www.iihs.org/ratings/ratingsbyseries.aspx?id=436
Good Front crash rating for the Acura
which one will you decide??!!! I will go with the car thats sportier and safer!!! TL ftw!!!
GhostTL09
09-19-2015 01:57 PM
spoiler900
5G TLX Photograph Gallery
09-11-2015 09:39 PM
ostrich
09-11-2015 04:28 PM
PAK74
09-03-2015 09:02 PM
Stu2414
4G TL Problems & Fixes
08-30-2015 07:30 PM
Quick Reply: Is the Acura TL SH-AWD 3.7L V6 engine as refined as the 3.5L V6 Lexus IS350?
