Acura TL 2012 AWD
Acura TL 2012 AWD
Hello everyone new to here my name is Moses. Wanted to see if anyone has any helpful thoughts or if this has happened to anyone. My 2012 TL is hesitating between 1st gear and like 4th gear no matter if is slow acceleration or fast. When I'm cruising at 3rd and 4th it does a hesitation like if the RPMs are fluctuating and you can feel it slightly and you can see the RPM going up and down at 5th & 6th its smooth. Can anyone help with this? it has 93K
Sorry to hear. I have 95,000 miles on my 2012 and do not have any transmission issues.
Sounds like a failing torque converter, have it looked at by a reputable shop.
If you have old trans fluid, it can cause a juddering in the trans. Acura has a TSB for this in which they flush the trans system with brand new fluid and do a software update. You should check and see if yours has been done.
