Acura branded calipers
I know that the 3g tl's came with the acura branded calipers. However I'm wondering if the 4g's also have them available? They always gave the car a little extra to the look. Thanks in advance
Received 6,470 Likes
You won't be able to find an OEM accessory part. But you could probably modify yourself.
אני עומד עם ישראל
^ cost. Those brakes were made by Brembo. Same thing with the demise of bi-xenon headlamps.
Cost cutting measures??
6G TLX-S
Just imagine how much more it would cost if they retained Brembo brakes and Bi-Xenon's!
Fawkatitle.com
Honestly the 4g still stops better then the 3g. It has a bigger brake system overall compared to the 3g, so your not missing much besides the eye candy if you want to look at it in that way. I always disliked the fact acura didnt go the complete package brembo front and rear for the 3g's... oh well..
BEAR-AvHistory (08-06-2012)
Fawkatitle.com
RPhilMan1 (08-07-2012)
Fawkatitle.com
no, sir.
Brake bias as in front to rear. duh....
and no sir, Brembos are only for brake fade.
the Automatic 3G TL's without brembos STOP SHORTER!!!!!
where the brembos shine is on a track with REPEATED STOPS, the brembos will dissipate heat better with the larger rotor.
Yes I am aware the regular 3g stopped 3ft shorter.
And I will not argue nor derail this post with ur "facts"...
Received 2,599 Likes
Also quick change pads, pull two pins & swap the pads.
justnspace (08-06-2012)
6G TLX-S
handsom-hustla
11-13-2015 05:04 PM
merc009
10-03-2015 12:59 AM
nuldabz
09-03-2015 05:49 PM
