Accident - Fender & Bumper Estimate
Bumper looks like it should be fine and need refinish/repaint for around $300-$400. Fender will be replaced and repainted, another $500 dollars. If the headlight is damaged that can be expensive! They will also check your suspension and make sure nothing was damaged, and may need to replace your hood hinges if the hood was pushed towards the driver side. I'd say less than 1K if the headlight is fine.
OR
you can find a used white bumper and fender and install them, should be less than $500.
OR
Best guess is about $1500 all in. Get an estimate.
$1501 :o
8th Gear
This costed $2000 to repair. They replaced the fender, bumper, headlight and mounting bracket for the headlight. If I had to do it over I would’ve got the insurance company to cut me a check and I would’ve bought pre-painted parts and installed everything myself and put about a $1000 in my pocket.
8th Gear
echodigital (09-24-2019)
