4G TL Technical Service Bulletins (TSB'S)
Listed Below are the Technical Service Bulletins that apply for 2009+ TL models.
I think it's working now. If anyone has a problem, send me a PM (not too many though lol).
IMPORTANT NOTICE
UPDATED 6 DECEMBER 2010
We have regained our access. Follow these instructions.
1. Open this link .
2. Select the entries as follows:
Acura
2010
TL
Then click on "submit vehicle information"
3. Open any one of the listings.
4. You can now open the below listed links.
Many thanks to TSXV6Guy for sharing this method with us.
2008:
TSB 08-041: 2009 TL: TQI of the Navigation System
TSB 08-042: 2009 TL:: TQI and New Model Information
TSB 08-053: Keyless Access Remote Doesn't Lock Into Its Slot and Won't Lock the Doors
TSB 08-055: (2009 TL and 2009 TL SH-AWD, See affected Range) Product Update: Front Compliance bushing Bolt Replacement
TSB 08-056: XM Radio, AUX, and USB Functions Don't Work
2009:
TSB 09-011: (2009 TL BASE) INFORMATIONAL ONLY, IMMOBLIZER
TSB 09-017: (2009 TL Tech Package) INFORMATIONAL ONLY, IMMOBLIZER
TSB 09-035: (ALL 2010 ACURAS) 2010 Acura Paint Codes
TSB 09-038: (2010 TL) 2010 TL: TQI Information
TSB 09-049: (2009 TL) MIL Comes On with DTC P1659
TSB 09-050: (2009 TL) Popping Or Clicking when Turning the Steering Wheel
TSB 09-057: (2009-2010 TL) Blower Speed Changes and VSA DTC's 104 and/or 86 are stored
TSB 09-059: (2009 TL) Front Door Pane Fabric Pulls Out Along Edge
2010:
TSB 10-008: (2009-2010 TL w/o push button start) Switchblade Key does Not Lock in Extended Position
TSB 10-014: (2009-2010 TL) Power Window Goes UP and REVERSES on it's Own, Is Slow to Open and Close, Or Squeals, Creaks, Clunks, or Clicks
TSB 10-015: (2009-2010 TL) Rear Headrest Button Sticks or Falls Out
TSB 10-017: (2009-2010 TL without Navigation) XM Information is Displayed, but there is NO sound
TSB 10-027: (2009 -2010 TL, See TSB For VIN Range) Door or Rear Shelf Speakers Rattle, or Sound Is Distorted
TSB 10-028: (2011 ALL ACURA) Paint Codes
TSB 10-029: 2011 TL: TQI and New Model Service Information
TSB 10-030: (2010 TL SH-AWD M/T) VSA System Indicator Is On With DTC 118; MID Indicates CHECK HILL START ASSIST SYSTEM
TSB 10-034: (2009-2010 TL) MIL Comes On With DTC P2118
TSB 10-041: (2010 TL SH-AWD M/T) VSA System Indicator Is On With No DTC Stored; MID Indicates CHECK HILL START ASSIST SYSTEM
2011:
TSB 11-005: 2012 TL TQI
TSB 11-013: 2012 Acura Paint Colors and Codes
TSB 11-016: (2012 TL w/ Nav) HFL Phonebook Imports Contacts each time, call history refreshes each time, voice tag doesn't work, acuralink voice unclear
TSB 11-024: (2009-2012 TL) Rear Self Area Clicks, Taps, or Ticks
TSB 11-025: (2009-2012 TL) Rear Rear Wheelwell Area Clicks, Taps, or Ticks
TSB 11-027: (2009-2012 TL) Upper B-Pillar or Moonroof Area Clicks, Rattles or Taps
2012:
TSB 12-002: (2009-2010 TL) Drivers Power Seat Feels Loose
TSB 12-008: 2013 Acura Paint Codes
TSB 12-013: (2012 TL) MID Shows Battery Charge LOW
TSB 12-028: (2013 TL) TQI Information
TSB 12-029: (2007-2009 MDX, 2009-2010 RL, 2009-2011 TL) WARRANTY EXTENSION: TORQUE CONVERTER W/ SOFTWARE UPDATE FOR LOCKUP FUNCTION 8YRS/105,000 MILES
TSB 12-041: (2009-2012 TL & TSX) Front Suspension Clunk in Hot Weather
2013:
TSB 13-007: Rattle or Vibration From the Rear Speakers (2009-2012 TL)
TSB 13-024: MIL Comes On With DTCs P0300 Thru P0306 (2013 MDX, 2013 TL SH-AWD, 2013 ZDX)
TSB 13-031: 2014 TL: TQI Information
TSB 13-032: 2014 TL: TQI of the Navigation System
IMPORTANT NOTICE
1. Open this link .
Acura
2010
TL
2008:
2009:
2010:
2011:
2012:
2013:
The following 3 users liked this post by csmeance:
AZ Community Team
Received 7,771 Likes
bump
bump, new tsb's added
