4G Headlight mod options?
I've been searching quite a bit and have not found much in the way of lighting mods without replacing the entire housing for $400+ each. I once stumbled upon clear or smoke side corder markers to replace the amber ones but I cannot even find those now. I think I'd be happy with compounding out the slight haze in my lenses and replacing the amber with clear/smoke and amber bulbs. Can anyone point me in the right direction for a good restoration kit/process and those clear/smoke pieces?
The Original Shawdy
Thank you carbonTSEX! One question regarding these, I've read about having to bake your housings in order to open them up yet I've also heard of people saying that these are very simple to install. I would not call a full removal, baking, separating installing and re-sealing a very simple process. Any pictures by chance?
Obviously the housing would need to be opened. It's that some are saying they're an easy install which I would imagine being a few screws and/or clips. The process of a total removal, baking, cracking open, then re-sealing... Well, that does not sound so easy.
any modifications to the headlights aside from tinting them/ changing the bulbs will require you to open them up. So depending on where you are, or if you're going to do it yourself, its either going to cost you a pretty penny, or its going to be a pain in the ass (especially if you don't reseal it properly)
The inconvenient truth
The Original Shawdy
While you are removing all the metal objects, it would be a good time to preheat your oven to 210 degrees F.
After the oven is preheated, place the headlight in the oven for 9 minutes.
Once they timer goes off, take the headlight out and you have to take apart the lens from the housing. This can be tricky but once you get one spot open, the rest should follow. (Try not to touch the inside of the lens, you do not want to use any chemicals to clean them).
From there you should be able to unscrew the reflectors and swap in the new one.
Put the lens back on and squeeze firmly, then place back into the oven for 9 minutes to heat up the glue. Once the timer goes off, pull it out and put the screws back in to help seal the lens. Gotta work quick to get the best seal and press around the edges. If you have small clamps, those would work great too. Once you have them sealed and cooled off, you can resamble everything else.
Repeat on other headlight.
It sounds harder than it is. The main thing is you want to reseal the lenses 100% or you most likely will get condensation. If this happens, you can rebake and try and seal it again. You do not need to take the lens off though.
Good Luck!
Cool thanks for the info, sounds like a bit of effort but defiantly worth it and something I could do. I was also wondering, does the white lens make the turn signal blink white? Thinking about it because the orange lens probably makes the turn signal light match the lower signal lights and the ones on the mirrors.
The Original Shawdy
Behind the reflectors are just corner lights and not turn signals. The light behind the reflector is just a white halogen bulb. The turn signals will still blink orange unless you buy LED switchbacks which I have. When the switchbacks are on they are pure white and when the blinkers are activated, they flash orange which matches the mirrors. As you can see from the picture, my corner lights, switchbacks and DRL's are all matching 6k high outputLEDs except for the switchbacks which are V3 Tritons all sold by VLEDS.com. Without the LEDs, the corners will be that washed out white, Same color as the factor DRL's.
![Name: BFA17A0A-88B6-443A-B0C5-DD136976BB63.jpg
Size: 122.7 KB](https://acurazine.com/forums/attachments/4g-tl-2009-2014-123/45202d1501261125-4g-headlight-mod-options-bfa17a0a-88b6-443a-b0c5-dd136976bb63.jpg)
