4G 3.7L having issues only in sports mode
@ this RPM and MPH it will not go any further without feeling likes something bad is about to happen, it hesitates and jerks while stuck on that RPM and MPH ( by stuck i mean unable to move any further up)
There was a code for p2426-00
We replaced the seal, switch and solenoid. Yet still having the same issue.
Any ideas?
Your check engine light is still on in the photo.
It likely has something to do with whatever is wrong with the car.
Have you tried using the paddles to manually shift to the next gear?
Any ideas?
I looked into this much further if it isn’t a lose wire it says it could be your powertrain control module (PCM) has detected an insufficient voltage in the EGR valve control circuit
You need someone with a volt meter to check it out
Ascension
05-29-2022 12:49 AM
