2013 TL sunroof question
I just picked up a 2013 TL. I notice when I look up at the sunroof I can see a spot on each side of the track where there is heavy grease. Is this normal?
Pretty sure that's part of the rails, and there should be a decent amount of grease there to keep things moving smoothly and quietly. Mine has a similar amount. If you wiped it off you can replace it with anything like Super Lube silicone grease.
White
