2012 TL SH-AWD: 5W-20 but Dealer may have put in 0W-20?
Hi,
Just got back from my first service (A1) on my TL with only 6000 or so miles on it after a year. A1 popped up at 15% Oil Quality minder, no issues there.
My ambiguity now is that the cap on the TL specifies 5W-20; the dealer printout indicated 0W20. Going back in, I was assured that it was a computer issue in their system and that the service tech confirmed he had put in 5W-20.
Any thoughts? Do I need to worry? Does it really matter? What happens with a slightly thinner grade at startup?
FanaticFan (06-27-2013)
if anything, i did a lip kit for a 2012 tl 2 weeks ago.. i saw that the oil cap on the engine shows that it needed 0w-20 for some reason..
i found that very odd
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
6G TLX-S
No need to worry.
My dealership has always been using 0w20 full synthetic Honda engine oil in all 2012+ TL's that are being serviced there.
Although the oils may be the same, for some reason Acura does not recommend 0w-20 in the 3.7 engine.
https://dl.dropboxusercontent.com/u/...s_Nov_2010.pdf
Mr Marco (06-27-2013)
This is the TL SH-AWD with the 3.7 engine; it is marked as needing 5W-20.
Called Acura Customer Relations, they checked it out and said it wasn't a problem. But I will remember to specify 5W-20 for all future changes, just because that's the recommendation.
Thanks for your help!
Received 2,329 Likes
I believe it was '11 or '12 when Honda started changing cylinder liners to use some molybdenum, reducing friction and also switched to 0w.
6G TLX-S
Back in early 2012 when I had my 1st oil change done, I asked the oil weight question, and my dealership said it received a service bulletin from Honda saying that all 2012 TL's (FWD/AWD/3.5L/3.7L) were recommended to use 0w20 full synthetic oil.
This is for the Canadian dealerships. Don't know if it also applies to the US TL's ?
ostrich
09-11-2015 04:28 PM
